outlawsix
- Joined
- Dec 19, 2014
- Messages
- 19
- Location
- Picayune, Ms
- Tractor
- Yanmar 240, Yanmar 240D, Cub Cadet 7265/Mahindra 2615, John Deere 4600 with 460 loader
I picked up a Case 580M earlier this week. it has been sitting for 3 years. So getting it to my place was a chore but now that it's here ive been going through it. Drained the hyd tank, fuel tank, changed engine oil and filter. Put a hose from the fuel pump to a can filled with Diesel. Got it all primed etc. Did remove 1 injector and took it apart. Put it in a bucket of carb cleaner to soak overnight. Couldn't even see the hole in the injector, so not sure if it is so small I cant see it or it is plugged off solid.
So anyway can not get it to turn over with the key. Can get it to turn over using a wire that the previous shad tree mechanic jury rigged. I took side consul apart this evening and its a mess. For some reason someone cut the wiring harness off and put slip on fittings on the wires, I don't even recall how many wires right now but there were two terminals on the ignition switch with nothing connected to them. Then found a red and black large gauge wire(10 gauge maybe) that had been cut and nothing attached to them. Waiting on my manuals to come in. But in the mean time does anyone have a wiring harness picture for the ignition module? Or even a picture of what colored wires go to each terminal on the switch?
When I turn the key I can hear the solenoid click, so getting power to at least that point. I replaced each fuse today and took each relay off, cleaned it and terminals and used di-electric grease on them. I know it can run, yes I used either, not wise but it will run.
Any help would be greatly appreciated. Thank you in advance.
