sportsman57
Hi-This is the first time I have posted a question. I have an old case 220 Ser. No. 9629639 which I believe is a 1969 model and it has a snow blade on which I use to plow snow. Recently I left it outside one night and it rained hard all night . Since then I have been unable to start it. When I turn the key I get nothing. I have it inside now so it has been dry for a few weeks. The wiring is a mess from the previous owner and the ignition is a jumble of wires and some wires have wire nuts and they go nowhere. I cant complain because I got it for free along with the deck and a snow blade. It always started before it got wet in the rain, but now, nothing. I am fairly handy doing simple mechanical stuff but when it comes to wiring I'm not too knowlegeable. I have a volt meter but really don't know how to use it. I read a post by Hydriv on how to re-wire the ignition and how to replace the old wires, but I would first like to find out why it wont start and what the problem is. I think it could be my ignition switch , as it was loose in the dash and I was having problems with it before it got rained on. Before when I turned the key, the Gen light would light up, now nothing. Does anyone know how I could check the ignition switch to see if its good or could I take one off my case 446 to use as a test.
I also have a 2 Case 446's (Onans) which I want to restore to use for snow removal and cutting the lawn. One is running but the carb needs to be replaced or rebuilt, and the fellow put on a electric fuel pump. The other came with the engine in a box as the gentleman I got it from said it stopped running one day and he let a friend he works with try to fix it. He disassembled the engine but when he couldn't remove the crank shaft he stopped the tear down. I since have found out on the web the way to remove the crank is to get a gear pully to remove it. It came with a snow blower, and a deck for 300.00. I got the other one that is running for 400.00 but only the tractor.
I really like the Case garden tractors and can see why so many people love to rebuild and restore them. This site is awesome for the information you can find and the members are so willing to share their knowledge on the repair and restoration of tractors.
