MechE1
- Joined
- Sep 4, 2013
- Messages
- 196
- Location
- Urbana, Il
- Tractor
- Ingersoll 448 with 42" tiller and 60" deck. John Deere 3046R, cab, T&T, H165 loader with 4and1, 60D Autoconnect, 72" boxblade, 59" snowblower
Also, forgot to mention. The voltage indicator issue. It may stay on for a bit and go away. You may have a regulator problem. Check the battery voltage when you are running. You should see normal recharge voltage. If it's high, find out why very quickly. You can fry the coil on the engine (don't ask me how I know). If low, then you are not getting enough charge. Be sure it's grounded well. When I got the machine it had a relatively new battery but did not have enough CCA's. After I changed to a "bigger" battery my voltage light calmed down.
