blueriver
Super Member
- Joined
- Oct 4, 2007
- Messages
- 5,025
- Location
- S.E.Oklahoma
- Tractor
- JD 5520 Montana 4340 Farmall Super A Montana 5720C
Some of you recall That Branson put a new clutch, pressure plate and throw out bearing under warranty recently ... well here's the deal and please anyone and everyone share your thoughts.
First a couple days ago the shuttle would not shift either forward or reverse per the dealer recommendation, I adjusted the clutch linkage to the point where it again shifted. This leaves me no further adjustment. Then a short while later I am now experiencing the following.
Smooth shifting in all gears as well as the shuttle however as I release the clutch pedal just at the point of engagement I have a noise not gear grinding more like a rattle/growling as soon as its fully released fine until I use the clutch again.
At low RPM'S I don't notice it... it appears to be at about 2000 RPM's it appears to be more frequent as the unit warms up.
