Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    Sep 2010
    Posts
    24
    Branson 4720
    Default Branson 4720 PTO problem
    I have a seven year old 4720 with 700 hours. I just bought a five foot 3pt tiller and am having problems when engaging the ground. At first it was OK but after about 30 minutes the PTO shaft quit rotating when the tiller is lowered to engage the ground. It also makes a "ratcheting sound internally. I even loosened the clutch on the tiller to allow slippage if I hit something and not slip internally but it made no difference.
    Any ideas?
  2. #2
    Platinum Member Zork's Avatar
    Join Date
    Dec 2003
    Posts
    780
    Virginia
    '04 Branson 3520, '51 Fergy, '96 MTD 18/46, '02 Craftsman GT5000/48
    Default Re: Branson 4720 PTO problem
    Check the other post; your's might be the same thing.
    He who is full loathes honey, but to the hungry even what is bitter tastes sweet.
  3. #3
    New Member
    Join Date
    Sep 2010
    Posts
    24
    Branson 4720
    Yes Sir, I found the other string after I posted this one so I highjacked it.
  4. #4
    Silver Member tjc1989's Avatar
    Join Date
    Oct 2006
    Posts
    106
    East Texas
    2006 Branson 4220i with FEL
    These might help a little in your planning .......
    Attached Thumbnails Attached Thumbnails Branson 4720 PTO problem-branson-differential-pto-clutch-jpg   Branson 4720 PTO problem-branson-pto-clutch-jpg
    I like to follow this principal: KISS - Keep It Simple Silly
  5. #5
    Join Date
    Dec 2003
    Posts
    780
    Virginia
    Quote Originally Posted by tjc1989 View Post
    First I must say nice photos and I have to compliment the manufacturer on the case and the contents because that's quality manufacturing and machining there.
    What I dont understand is why would hydraulic pressure effect those clutch disc's if they are held in compression by the tension of those springs. To me your photos appear to show a mechanical slip clutch within the shaft of the PTO; so why would hydraulic pump pressure effect those springs? It would seem to me that the amount of torque applied to the shaft via hydro motor dependent on hydro pressure would not effect something mechanical. Someone please help me.
Similar Threads
  1. 4720 won't crank - both PTO indicators lit...
    By Karl2 in forum John Deere Owning/Operating
    Last Post: 04-28-2012, 09:05 PM
  2. 4210 Operator Off Seat Rear PTO Problem
    By GoodGuy in forum John Deere Owning/Operating
    Last Post: 08-05-2008, 08:12 PM
  3. JD 4600 HST PTO Problem
    By kabeman in forum John Deere Owning/Operating
    Last Post: 07-22-2008, 12:09 PM
  4. TC34DA, Mid Pto Problem
    By mjonesnh in forum New Holland Owning/Operating
    Last Post: 09-08-2007, 10:35 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
