Results 1 to 2 of 2
  1. #1
    Member
    Join Date
    Dec 2012
    Posts
    36
    Illinois
    Branson 3510i
    Default 50 Hour Service
    I have a 3510i that will be getting a 50 hour service as soon as the weather breaks. I know many posts have discussed this but I was hoping to get a good list of tips and "dos and don'ts". The owner's manual doesn't seem to be a lot of help. Seems I have read a lot of posts on hydraulic filters, multiple drain plugs, hidden drain plugs, fuel filter issues, etc. Thanks for any tips you could give me!
  2. #2
    Join Date
    May 2005
    Posts
    2,045
    N. E. Florida
    Default Re: 50 Hour Service
    Things I had to learn-
    There is a drain plug under the driveshaft at the front of the rearend. (I found it after draining from the screen area)
    You need at least 3 5 gal buckets because there is a lot of fluid to drain.
    The first service is the important one! You remove any trash left from manufacturing.
    OEM hydraulic filter is best as others have had issues with generic.
Similar Threads
  1. 50 Hour Service
    By paulwestski in forum Kubota Owning/Operating
    Last Post: 04-22-2011, 11:09 AM
  2. 50 hour service
    By carhartt56 in forum Kioti Owning/Operating
    Last Post: 04-19-2011, 09:51 PM
  3. Oil & Fuel 50 Hour Service
    By Davebota in forum Kubota Owning/Operating
    Last Post: 04-11-2011, 05:42 PM
  4. 50 hour service
    By unclesalty in forum Bobcat Tractors
    Last Post: 06-25-2009, 08:30 PM
  5. 50 Hour Service
    By strez in forum New Holland Owning/Operating
    Last Post: 12-28-2003, 04:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
