Results 1 to 2 of 2
  1. #1
    New Member
    Join Date
    Apr 2006
    Posts
    24
    S.E. Michigan
    Default 3510 with broken clutch return spring
    I have had my Branson 3510 for 10 years now and use it regularly around my 11 acres, it has never let me down, ok except for a fuel pump issue that was probably my fault.
    Today is my first event. After using the machine for a few minutes I pushed in the clutch felt some slight resistance then heard a "popping" noise and a broken spring fell onto my foot. The machine still works however the clutch reurn is obviuosly different (very slow). Anyone have this happen? How do I get a new spring and where in the heck is it supposed to be? I cannot see where it may have come from. Any help would be appreciated
  2. #2
    New Member
    Join Date
    Apr 2006
    Posts
    24
    S.E. Michigan
    Default Re: 3510 with broken clutch return spring
    Simple fix Part number TC73090000A4. $15 spring that should cost no more than 5 bucks.
Similar Threads
  1. Reverse Return Spring
    By Whiteclover in forum Kubota Owning/Operating
    Last Post: 05-22-2011, 03:44 AM
  2. Broken Clutch Spring on TN70A
    By Doc_Bob in forum New Holland Owning/Operating
    Last Post: 10-25-2008, 03:07 PM
  3. TC40D Broken return spring/ Won't start
    By Windyacres in forum New Holland Owning/Operating
    Last Post: 07-24-2006, 07:04 AM
  4. My Second Broken Clutch Spring!
    By Glenn9643 in forum Massey Ferguson Owning/Operating
    Last Post: 08-12-2005, 08:22 PM
  5. Clutch Return Spring
    By grainger12002 in forum New Holland Owning/Operating
    Last Post: 10-02-2003, 11:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
