Have been having problems with a Branson 3510 PTO that has baffled several highly experienced tractor users. The Tractor is 9 years old and have had it since day 1. Recently, the PTO started shutting off while mowing and after replacing the fuse seemed to work. Then it shut down again while mowing. This was intermittent at first then became very frequent. I wound up replacing the PTO switches (both front and rear) and thought it was fixed then it shut down again. I then inspected the fuse block and found minor corrosion on the terminals so I cut the leads and installed a separate fuse block for the PTO. Now everything electrical has been replaced. Trying to determine if there is a coil or some relay that could be causing the problem. The manual is not clear enough to trace all components. I did take it to a dealer and put it on a servo to test the mechanical components and everything mechanically seems fine. Anyone out there have any suggestions?
