Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Join Date
    Sep 2015
    Posts
    196
    Elm Mott, TX
    Farmall 404
    Default 3-hoses on loader valve - what does what?
    There are 3 hoses on my loader valve - what does what?
    Red:
    Orange:
    Green:
    I would like to add a remote for my log splitter,
    which has pioneer couplings and it's own control valve.
    3-hoses on loader valve - what does what?-loader-hoses-jpg
    '05 Branson 3510i with BL-10A loader & "construction" tires, '49 Farmall C, '50 Farmall C, '51 Farmall Super C, '53 Farmall Super C, '43 Farmall H, '50 Farmall M, '63 International 404 utility, '64 IH 2404 Industrial w/IH 2000 loader, Yanmar YM2000, YTO-180 with single-cylinder, direct-injected Chang Chai ZS1110 engine.
  2. #2
    Super Member /pine's Avatar
    Join Date
    Mar 2009
    Posts
    7,550
    Default Re: 3-hoses on loader valve - what does what?
    What do the indicators say?...just guessing...green is pressure, red is return and the orange is power beyond back to the 3ph...just a guess...
    Slash Pine
    blunt and succinct yet sincere I don't suffer fools and morons...in the immortal words of Popeye..."I yam what I yam"
  3. #3
    Join Date
    Mar 2009
    Posts
    7,550
    to plumb a new valve (it must have power beyond capability)...the pb port on the existing valve will become the pressure line for the new valve..."T" the new return/tank line into the existing return/tank line...and connect the pb port on the new valve back to the 3ph
    Slash Pine
  4. #4
    Join Date
    Sep 2015
    Posts
    196
    Elm Mott, TX
    Farmall 404
    Quote Originally Posted by /pine View Post
    There are no indicators or markings of any kind
  5. #5
    Join Date
    Sep 2015
    Posts
    196
    Elm Mott, TX
    Farmall 404
    Yes, thank you……
    That part I already know.
    I just want to know what each port does before I start taking lines loose
  6. #6
    Join Date
    Sep 2015
    Posts
    196
    Elm Mott, TX
    Farmall 404
    The tall hexagon thing under the port with the red arrow is the pressure relief valve, which makes me think red is pressure coming in.
    I don't know if green or orange is power beyond.
  7. #7
    Join Date
    Mar 2009
    Posts
    7,550
    Quote Originally Posted by LincTex View Post
    After a second look I think you are right...I was looking it at upside down...with all the valves I have you would be correct...
    can you trace the hoses to see where they go? and just to be sure check the parts list diagrams for a description...
    Slash Pine
  8. #8
    Elite Member
    Advertiser
    MtnViewRanch's Avatar
    Join Date
    Mar 2005
    Posts
    9,414
    4000\' mountains of Southern California
    Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
    More than likely the red line is your pressure into the loader valve. The green is your power beyond (pressure out) and the orange is your return to tank line. The fitting under the green line is most likely the power beyond adapter plug.
    If you want to make it simple and as economical as possible, just run a line from the green port to the back. Have a set of couplers at the back. Then run a return line to were ever the green line now connects. This will make a complete loop. Couple the hoses at the rear together or uncouple and insert your log splitter. This will work as is. If your log splitter is a 3 line system, then you will need to tee into the return to tank link with the return to tank line on the splitter.
    Pretty simple, just have to remember that the lines at the rear MUST ALWAYS BE COUPLED, either to themselves or to the log splitter.
    Brian
    Top and Tilt Kits by Fit Rite Hydraulics
  9. #9
    Elite Member
    Join Date
    Sep 2007
    Posts
    3,420
    Doniphan, Mo.
    Kubota L4240, B7800 & BX2660
    Quote Originally Posted by MtnViewRanch View Post
    That is right the green is PB.
  10. #10
    Join Date
    Mar 2009
    Posts
    7,550
    A way to be sure about which one is the pb port...remove the line and the adapter and see if there is a removable plug inside...
    Slash Pine
Similar Threads
  1. Replies: 8
    Last Post: 08-25-2016, 05:08 PM
  2. Replies: 2
    Last Post: 05-15-2015, 05:15 PM
  3. Replies: 5
    Last Post: 12-06-2014, 09:45 AM
  4. Replies: 13
    Last Post: 01-28-2014, 08:03 PM
  5. What valve and hoses to buy?
    By rbento in forum Hydraulics
    Last Post: 02-01-2009, 01:33 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
