Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    Join Date
    Jul 2005
    Posts
    157
    Woodland, Washington
    Branson 3510i w/FEL
    Default Re: Branson 2910 warranty work
    Could someone possible post a pic of the valve. I can't seem to locate it.
    thanks
  2. #12
    Elite Member
    Join Date
    Nov 2005
    Posts
    3,112
    Quote Originally Posted by Yalerider View Post
    thanks
    I know this is an old thread, but if anyone still has a problem finding this;
    Look at the line of injectors.
    Find a tube that links them together, this is close to the cylinder head.
    Follow it from the forward cylinder down to the top of the injector pump, where the check valve is mounted.
    The other tube from that valve goes back toward the firewall to the tank.
    Doubtful that anyone still needs pictures, but I will take some if anyone wants them.
  3. #13
    New Member
    Join Date
    Jun 2012
    Posts
    15
    Russellville, KY
    Branson 2910
    Default Re: Branson 2910i
    thanks
    My question is do you take it out completely or do you put it in the return line. Both lines have the same looking check valve. No one has said if you remove it completely or move it to return line. I also would like to picture of before and after. The Branson 2910 I have is used so I'm new to this tractor.
  4. #14
    New Member Old Navy's Avatar
    Join Date
    Oct 2010
    Posts
    15
    South Central,Oklahoma
    Branson 2910i
    A picture is worth a thousand words.
  5. #15
    New Member
    Join Date
    Jun 2012
    Posts
    15
    Russellville, KY
    Branson 2910
    This true about a pic. I can find the valve; but do I take it out and reconnect the line. Discarding the valve completely. It appears to have same check valve in return line so I would not need another one in return......Help me get rid of the excessive smoke on startup.......Thanks
  6. #16
    New Member
    Join Date
    Jun 2012
    Posts
    15
    Russellville, KY
    Branson 2910
    Branson 2910 warranty work-img_20121011_165557-jpg
  7. #17
    New Member
    Join Date
    Jun 2012
    Posts
    15
    Russellville, KY
    Branson 2910
    Picture posted on 2910 warranty thread..Page 2...Need clarification on procedure
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
