Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Silver Member lakespirit's Avatar
    Join Date
    Jul 2006
    Posts
    244
    Idaho Panhandle
    2004 KAMA TS254C
    Default tie rods
    My KAMA TS254C is constantly stripping the threads on the tie rod connection between it and the steering cylinder rod. They're the beefier 18mm parts, but still I am thrashing them very quickly.
  2. #2
    Super Member greg_g's Avatar
    Join Date
    Dec 2003
    Posts
    6,086
    Western Kentucky
    JD3720 Cab, 300X loader with 4-in-1 bucket
    Default Re: tie rods
    Can you use the diagram to identify which part(s) keep stripping?
    //greg//
    Attached Images Attached Images
    USN (Ret)
    Former Chinese tractor owner (x4)
    Current John Deere owner
  3. #3
    Join Date
    Jul 2006
    Posts
    244
    Idaho Panhandle
    2004 KAMA TS254C
    P/N 26, the female threads.
  4. #4
    Join Date
    Dec 2003
    Posts
    6,086
    Western Kentucky
    Quote Originally Posted by lakespirit
    I have a problem with mine, only it's with parts 22-23-24. I can't get grease into zerk #22, because the ball end of #24 is blocking the hole in #23. I have to disassemble mine, apply grease, then reassemble. I wonder if the two issues are related?
    How far can you get #26 to thread into #23? If I recall correctly, mine threads in all the way. Perhaps if you see too many exposed threads, there might not be enough inside to hold the assembly rigid enough.
    //greg//
    USN (Ret)
  5. #5
    Join Date
    Jul 2006
    Posts
    244
    Idaho Panhandle
    2004 KAMA TS254C
    It starts with virtually all 24mm engaged, which is all the thread.
  6. #6
    Gold Member
    Join Date
    Mar 2006
    Posts
    328
    Ky
    JD 2240, NHTD80D
    I've had the same problem as Greg as far as not being able to get grease in. I've never had one strip though.
    I did notice not long after I got the tractor that there was an extreme amount of slop in that joint. I put some more washers in there to shim it.
    The socket and ball are good and tight now.
    Could be your steering stops on the wheels are letting the wheels turn to far as well.
  7. #7
    Join Date
    Jul 2006
    Posts
    244
    Idaho Panhandle
    2004 KAMA TS254C
    Never thought about the stops. If I can get it started, I'll take a look at that. Thanks.
  8. #8
    Super Member 3RRL's Avatar
    Join Date
    Oct 2005
    Posts
    6,825
    Foothills of the Giant Sequoia's, California
    55HP 4WD KAMA 554 and 4 x 4 Jinma 284
    Right, check the stops.
    There was a thread about breaking the tie rod ends ... the casting part. Turned out the stops were not set correctly letting the cylinder continue to push hard on the tie rods, which snapped them off.
    Rob-
    ...The Older I get...the Better I Used to be...
    Member of the Month
  9. #9
    Join Date
    Jul 2006
    Posts
    244
    Idaho Panhandle
    2004 KAMA TS254C
    How do you know when they are too far??
  10. #10
    Join Date
    Oct 2005
    Posts
    6,825
    When you turn the wheels as far as they go using the steering wheel, the stops should hit at that moment. Do that for both directions. I actually have mine set so there is a tiny gap left after the wheels are turned their farthest, but I tried to set it to be as I described above. Others may set them differently.
    Rob-
    Member of the Month
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
