3RRL
Super Member
- Joined
- Oct 20, 2005
- Messages
- 6,825
- Tractor
- 55HP 4WD KAMA 554 and 4 x 4 Jinma 284
With all this talk of getting my steering to work better, I was going to remove the power steering cylinder and dis-assemble it to check for nicks or whatever to see if I could find anything obviously wrong with it and repair it if needed. I noticed that the bolts holding the mount to the front axle had come loose. In order to get to those bolts on the top, I needed to remove the pivot pin to get to the last one. You can barely get a wrench on it and you can't get a socket on it because the pin that holds the cylinder on and the Zerk get in the way.
Here is the cylinder, the mounting bracket on the axle housing and a close up.
These pictures show a good view of the pin that holds the cylinder in the bracket and the little bolt that holds the pin in place. I removed the little bolt and slid the pin up to get it out. Guess what? The pin's shoulder hits the casting above it. In order to get the pin out, I'll somehow have to cut off part of the shoulder and also part of the pin. When the pin is lifted up and against the casting, it is still engaged to the cylinder clevis, so I'm NOT sure how much of the pin and shoulder will need to be cut off. Needless to say, doing all that upside down and under the tractor will not be easy. What can I get in there to cut with?
Then if I ever did get the pin out, I was going to turn the bracket upside down so the pin would go in from the bottom, but you can see the bracket is not symmetrical! If I want to have the pin go in from the bottom, I'll have to drill and tap the bracket. Plus the pivot will not be in the same place. Needless to say, I probably won't do that anyway.
I decided to wait until I have more time. I have the filter on order, so I'll wait to do the whole thing when that gets here. If you're following my Log Home and Barn Thread, you'll see I have plenty of other stuff to do. Even trying to tighten those bolts was a pain.
How did those Chinese assemble this thing in the first place?
