Results 1 to 6 of 6
  1. #1
    Veteran Member Kernopelli's Avatar
    Join Date
    Oct 2006
    Posts
    1,870
    Carterville, Illinois
    Mitsubishi MTE2000D, Dig It 258 Backhoe Deere Z930M ZTR
    Default PTO won't engage on 284
    Well, this beats all! I hadn't been on the Jinma for several days and went out a minute ago and was going to mow a little spot and engaged the PTO and nothing. The PTO does begin to turn but just barely, in fact you could probably stop it with gloved hands. It worked perfectly last time I used it so this is quite sudden.
    I am going to assume the PTO clutch is slipping/out of adjustment. I took the left inspection plate off and didn't see anything too suspect. There are 6 lugs or fingers, what ever you want to call them. 3 of them have adjustment nuts ( first pic) and 3 have a spring and washer sitting against a nut ( second pic).
    Does this sound like I'm on the right track or is there something else I need to check? I am certain the gears are OK, at least it sounds and feels like there is positive engagement when you move the lever to on and the PTO has no movement until you put the lever in "ON" position..
    I need to know how to check for proper adjustment and how to adjust it if it is off.
    Thanks.
    Attached Thumbnails Attached Thumbnails PTO won't engage on 284-003-jpg   PTO won't engage on 284-004-jpg
    Darryl
  2. #2
    Advertiser
    Join Date
    Mar 2004
    Posts
    1,456
    Texas
    Default Re: PTO won't engage on 284
    I have never seen a PTO clutch go out like that,I would check both engagement levers,the one at the rear make sure it's in 540 and the engagement lever by your right leg to be sure they are both engaged.I can't tell you how many tractors were brought to us with the rear PTO speed selector that got knocked into neutral
    Tommy
    Affordable Tractor Sales
    " Your Jinma Parts Superstore"
    Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
  3. #3
    Join Date
    Oct 2006
    Posts
    1,870
    Quote Originally Posted by Affordable View Post
    Tommy
    Tommy, not only are you lightning fast on a reply but you were absolutely correct.......I feel like an idiot that it didn't occur to me to check that first.
    This tractor is on Ebay as we speak and I've got nearly 40 "watchers" right now and bidding is closing in on the reserve price. I was about to FREAK OUT.
    YOUR THE MAN!!!! BTW, when I sell this machine, rest assured that I will be giving them your contact info.
    Thanks again!!
    Darryl
  4. #4
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Check the pto speed selector. Its at the rear and has 1000/neutral/540. Heard of many getting bumped into neutral.
    Chris
  5. #5
    Elite Member
    Join Date
    Jul 2006
    Posts
    4,409
    Northwest, WA
    Chris, did you miss part of this thread ?
    ::Sent from a standard desktop keyboard::
    My Photobucket
  6. #6
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    I got it now Willl. Guess Tommy beat me to the punch. He is a sharp cookie!
    Chris
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
