HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Brand Specific Forums > Chinese Tractors
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 10-13-2009, 11:01 PM   #11 (permalink)
New Member
jjkane's Avatar
Default Re: Tachometer problem on a Jinma 284
Tommy
All the other gagues in the cluster work that includes the fuel and ampmeter but the center portion is a combination tach and hour meter. I've been able to take the cluster apart so the picture I am posting is just the tach.
jjk
tachometer-problem-jinma-284-dscf0052.jpg  tachometer-problem-jinma-284-dscf0054.jpg
jjkane is offline   Reply With Quote
Old 10-17-2009, 09:44 PM   #12 (permalink)
New Member
jjkane's Avatar
Although the tachometer is not as critical as things like temperature and oil pressure gages are but it is a handy bit of information when running things like a backhoe. Since the tach is an integral part of the instrument cluster I am trying to consider other options to get it running. I believe earlier models of Jinma tractors had individual gages instead of the cluster. I'd like to replace the cluster with individual gages and wondered if anyone has any experience with this. The question is if the sending units on the engine are compatible with the older gages. Any information would be greatly appreciated.
thanks
jjkane
Old 10-21-2009, 08:34 PM   #13 (permalink)
I followed the below directions, and my hugely annoying intermittent tach now operates correctly. Thanks
Jeff
Quote:
Originally Posted by quicksandfarmer View Post
The most common problem is that the sensor has moved a little and is too far away from the flywheel. The first step is to make sure that the sensor is close enough to the flywheel, it should be about 1mm. The way to do this is: (with the engine off!) loosen the locknut, screw the sensor in until it touches, and then back it out 3/4 of a turn and tighten the locknut.
jeff_jeff is offline   Reply With Quote
Old 11-01-2009, 01:46 AM   #14 (permalink)
New Member
jjkane's Avatar
Thanks Jeff
I'll check it tomorrow if the weather holds out for me.
jjkane
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.16276 seconds with 9 queries
