HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Brand Specific Forums > Chinese Tractors
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 10-03-2009, 10:37 PM   #1 (permalink)
New Member
jjkane's Avatar
Default Tachometer problem on a Jinma 284
The tach on my 284 up and quit a while ago and I am finally getting around to fixing it. I checked the sending unit and it generates approximately 4.5 to 5 volts AC at idle and increases as RPM's are increased. The tach doesn't work at all. My question is what voltage should I expect to see from the sending unit at idle and at a higher RPM?
jjkane
jjkane is offline   Reply With Quote
Old 10-03-2009, 11:41 PM   #2 (permalink)
RonMar's Avatar
Default Re: Tachometer problem on a Jinma 284
The sending unit isn't really generating a voltage. Well it is as it is a hall effect sensor(coil in core) that reacts to the ring gear teeth passing in close proximity to the sensor. The signal that the tach gauge is reacting to is the frequency change as the pulses become more frequent as the RPM increases. The fact that it is putting out a voltage indicates that the sensor is probably OK, and the gauge is failing to make use of it...
__________________
Ron
RonMar is offline   Reply With Quote
Old 10-04-2009, 11:31 PM   #3 (permalink)
These sensors are notoriously fickle. As Ron indicated, the tach works on frequency, not voltage, so it's difficult for someone without an oscilloscope to verify operation. The 5V is a good sign though.
The most common problem is that the sensor has moved a little and is too far away from the flywheel. The first step is to make sure that the sensor is close enough to the flywheel, it should be about 1mm. The way to do this is: (with the engine off!) loosen the locknut, screw the sensor in until it touches, and then back it out 3/4 of a turn and tighten the locknut.
The next thing to test is whether that 5V signal is getting all the way to the tach input on the dashboard. If it is, my understanding is that the entire instrument panel needs to be replaced, there is no repair for the tach.
quicksandfarmer is offline   Reply With Quote
Old 10-05-2009, 10:29 AM   #4 (permalink)
bjr
Gold Member
Has anyone tried the replacement tachs at Surplus Center? I called once and was told all they had were the heads and no senders/ transducer units? Why would they try to sell incomplete units? bjr
bjr is offline   Reply With Quote
Old 10-05-2009, 10:44 AM   #5 (permalink)
Gold Member
Bob Rooks's Avatar
Quote:
Um, because they are surplus?
__________________
'06 Yuchai YCT306R-5A Bulldozer w/QZ-05 FEL and LiTW BH7600 BH powered by a Prince HC-7A PTO pump, 6' Rollins box scraper, 5' Thurston root rake, 6' Rhino rock rake, 6' Rankin grader-scraper, HF Quick Hitch, TPH Receiver Hitch, 1,600 lb. cap. Dozer Crane, Rankin single shank parabolic ripper. (Yellow Swiss Army Knife)
Bob Rooks is offline   Reply With Quote
Old 10-05-2009, 11:51 AM   #6 (permalink)
JJ
When mine quit working I ajusted it according to the instructions above and it worked for while longer then quit -- new sensor is cheap and the most likely solution
studor is offline   Reply With Quote
Old 10-05-2009, 12:36 PM   #7 (permalink)
Quote:
Originally Posted by studor View Post
JJ
I had exactly the same experience, $19.50 plus shipping for a new sensor. I'll also add the that the guys who sell Jinma parts tend to get them to you on the double, I think I had a new sensor in the tractor two days after I ordered it.
Old 10-05-2009, 06:10 PM   #8 (permalink)
New Member
jjkane's Avatar
Thanks to all who have replied. If I get home early enough one day this week I'll investigate further the wiring to the instrument cluster. I also have a scope I can put on the sender leeds to check for the change in frequency as the PRM's are increased.
Thanks
jjk
Old 10-13-2009, 12:08 AM   #9 (permalink)
New Member
jjkane's Avatar
Here is an update on the tach problem. I found I was able to disassemble the instrument cluster and seperate the other gagues from the cluster leaving just the hour meter and tach in one piece. There is a board that is most likely the problem. If anyone has any defective cluster panels maybe I can get what I need to get a working set from them. Any help would be appreciated.
Thanks
jjk
Old 10-13-2009, 07:35 AM   #10 (permalink)
Approved Advertiser
Can you send me a pic of what you need,I have a few used cluster panels that have single gauges that did not work,1-had a bad fuel gauge that I have been keeping for parts
tommy@affordabletractorsalesco.com
Tommy
Affordable Tractor Sales
"Your Jinma Parts Superstore"
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
Affordable is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.20907 seconds with 9 queries
