robert421960
ok guys heres another problem
2006 farmpro 2425
i almost always have to ues 4wd here at my home in se ky but the other day i was bushogging up at my dads house and took it into 2wd so i came to a wet area and went back to 4wd but it didnt work
the lever works fine but front tires dont pull
i came home and pulled cover over shifter and examined it all
seems to be working fine and engaging inside there
i left the cover off and started the tractor and used the fel to raise front tires off the ground
moving tractor back and forth
i watched the lower gear appear to work fine
so tell me am i thinking right here?
what is the cover over im assuming drive shaft?
is there a shear pin or something like it?
2006 farmpro 2425
