Results 1 to 4 of 4
08-06-2010, 02:05 PM #1
- Join Date
- Aug 2010
- Posts
- 3
- Tractor
- Jinma 284 (2007)
2007 Jinma 284 No Start
I searched this site before I performed my own troubeshooting using the recommendations made by others for similar problem.
This is a 2007 Jinma 284 with 9 hours. Hasn't had much use as you can tell I relocated it back in April and didn't try to start until yesterday. Turns over but no fuel detonation so will not start.
Here is what I've checked and done: Inspected all fuel lines and strainer inserts through the circuit from tank through delivery pump, fuel filter, inlet of injection pump and it's outlet al the way through the last injector to
tank return. Loosened nuts at injectors hardly any fuel dribbling out.
Tank bowl strainer is clean...no bugs.
Opened inspection cover to injector pump, fuel rack moves back and forth easily and is in the forward position, kill switch in forward position as well. Pistons are moving sprayed throttle body cleaner in there anyway. Reinstalled cover.
Used hand primer on injector pump and get nice firm delivery all the
way to the last injector return fitting before it connects to tank.
Went ahead and drained injector pump oil and flushed it out with K1 kero and mineral spirits after a cpl hours soak time, wasn't very dirty. Refilled with fresh 10W oil. Removed two injector lines from top of the pump and spun engine over with decompression lever enabled, weak delivery...small low height squirts.
Loosened fuel inlet line to injector pump, spun engine again very little fuel coming out. Get a **** of a good squirt when I use the prime pump.
Removed the large nut that houses the spring-loaded piston in the delivery pump, piston moves freely. Closed back up.
Seems to me the delivery pump should force pretty close as hard a pressure that the hand pump delivers. So I think at this stage I'm starving the inlet to the injector pump. I didn't remove the governor end as I felt the solvent soaking I gave the unit earlier should clean things up if needed.
Looks like there is a plug for a test gauge on the left side fuel line on the upper body of the pump. Any idea how much pressure should be measured there?
I'm outta ideas to get this fired back up, seems an unlikely the delivery pump is bad at 9 hours. No longer under warranty and dealer here has folded. Rocky Mountain Farm Pros.
Thanks for any help!
Regards,
HitnMiss
08-06-2010, 07:19 PM #2
- Join Date
- Aug 2010
- Posts
- 3
- Tractor
- Jinma 284 (2007)
Re: 2007 Jinma 284 No Start
My fuel tank was half full when I began this problem, didn't want to drain a full tank if needed. Anyway, topped off the tank and decided to try another start, dadgum engine began to catch and finally lit off.
Im wondering if topping off the tank increased static pressure enough to the lift pump to finally get things rolling. Is it possible there is a weakness in the lift pump? Shouldn't be this temperamental at half fill.
08-06-2010, 11:07 PM #3
- Join Date
- Dec 2003
- Posts
- 6,086
- Location
- Western Kentucky
- Tractor
- JD3720 Cab, 300X loader with 4-in-1 bucket
No, I think you just coincidentally had nearly all the air out of the high pressure side of the pump. The hand primer only pushes fuel through the low pressure side (the flexible fuel lines). Cranking the engine is required to get it through the injection pump/hard lines/injectors. So whether or not you topped off the tank, it probably started anyway.
//greg//USN (Ret)
Former Chinese tractor owner (x4)
Current John Deere owner
08-08-2010, 09:03 AM #4
- Join Date
- Jan 2007
- Posts
- 16,332
- Location
- Daleville, IN
- Tractor
- Jinma 254/284 Ford 861 Powermaster at work
I think it was just dumb luck it started after you added fuel. I must say you did a excellent job of trouble shooting and getting it going by searching this thread.
99% of the time we get a guy on here that simply says it will not start. We spend a week trying to figure out the basics playing ask a million questions. Your post should be the model from now on.
Great job.
Chris
Similar Threads
Jinma 284 won't start
By meporsche in forum Chinese TractorsReplies: 20Last Post: 12-08-2009, 07:17 PM -
Freeze Plug Blues
By mostly_gas in forum New Holland Owning/OperatingReplies: 11Last Post: 09-22-2009, 03:17 PM -
insttalling hydraulic pump on 1920
By jab-law in forum New Holland Owning/OperatingReplies: 6Last Post: 09-01-2009, 06:48 PM -
Jinma will not start (blown fuse)
By jaroban in forum Chinese TractorsReplies: 14Last Post: 08-12-2007, 03:54 PM
