Results 1 to 4 of 4
  1. #1
    Member
    Join Date
    Oct 2009
    Posts
    45
    Northern Tier of PA
    Default Jinma 284 ignition switch
    Hello,
    Once again my ignition switch does not work. It has self-healed in the past but now, nothing. It's getting annoying starting it with a screwdriver. Is there a swap in ign switch from a more reliable mfgr, or am I stuck buying another Jinma POS switch?
    Thanks,
    Darwin
  2. #2
    Super Member greg_g's Avatar
    Join Date
    Dec 2003
    Posts
    5,587
    Western Kentucky
    JD3720 Cab, 300X loader with 4-in-1 bucket
    Default Re: Jinma 284 ignition switch
    Absolutely. The document is old, but I've uploaded a copy anyway. And I've got an extra one of those switches if you're interested.
    //greg//
    Attached Files Attached Files
    USN (Ret)
    Former Chinese tractor owner (x4)
    Current John Deere owner
  3. #3
    Veteran Member GuglioLS's Avatar
    Join Date
    Feb 2005
    Posts
    1,111
    Edgewood, NM USA
    Jinma 354, Ford 1953 NAA Golden Jubilee, Komatsu Bulldozer
    Have you ruled out the clutch safety switch? It wont turn over unless the clutch safety switch is closed. There could also be a corroded fuse that supplies power to the switch or starter solenoid circuit, might be worth removing and cleaning every fuse just to make sure that's not a problem. Attached is a pic of the "Ford" switch to supliment the info Greg supplied. Google search part# E7NN11N501AB to find a supplier. Nice of Greg to offer his spare switch. A bunch of us on another forum upgraded our switches along with installing Delco 12SI alternators. I bought all the swithces to send out to the members and have a few spares myself.
    Larry
    Attached Thumbnails Attached Thumbnails Jinma 284 ignition switch-switch-connections.jpg   Jinma 284 ignition switch-switches.jpg
    My Fortune cookies:
    If you have to ask if you can do something, you probably can't.
    Life is short, especially if you forget to wake up the next day.
    He who hurries wastes time.
    If you must select between two evils, choose the one you haven't tried before.
    Tractor hydraulics is not rocket science.
  4. #4
    Join Date
    Feb 2005
    Posts
    1,111
    Edgewood, NM USA
    Followup...
    This is the best supplier with the lowest price and most reasonable shipping I could find...
    CLICK HERE scroll down and find part # E7NN11N501AB
    Pin / connection
    1 / Off connect to hot (+12 )
    2 / For tractor power (Lights, gauges) + any accy's.
    3 / To glow plugs
    4 / To alternator field winding (provided you upgraded to the Delco 12SI)
    5 / Starter solenoid (through clutch safety switch)
    Here are the contacts vs key position:
    Key position starting all the way CCW
    Key Position 0 - 4
    0 - OFF (no connection) except +12 to pin 1 of the switch
    1 - (1 click CW) Pin 1+2 (Tractor lights and gauges only)
    2 - (2 clicks CW) Pin 1+2+4 (Delco Alternator 12SI field energize) + Tractor power, lights, gauges + any accys).
    3 - (3 clicks CW Spring return back to 2) 1+3 (Glow Plugs only)
    4 - (4 clicks CW Spring return back to 2) 1+3+5 (start+glow plugs)
    Of particular note - this switch is one of few were glow plugs are hot at same time starter is engaged. The OEM switches do not do that so it's a definite advantage to have one of these switches installed (provided you have glow plugs).
    Larry
    My Fortune cookies:
Similar Threads
  1. 4 x 4 light mode, on a Jinma 284
    By Turbo in forum Customization
    Last Post: 04-05-2010, 12:48 PM
  2. DF-354 : Ignition Switch Substitution?
    By mpaschetto in forum Chinese Tractors
    Last Post: 09-06-2009, 07:26 PM
  3. BX 24 Ignition Switch
    By megaboz in forum Kubota Owning/Operating
    Last Post: 03-04-2009, 10:46 PM
  4. Kubota B6100 ignition switch question
    By txdave05 in forum Parts/Repairs
    Last Post: 01-17-2005, 08:35 PM
  5. Ignition switch problem
    By davesisk in forum Power Trac
    Last Post: 10-15-2002, 03:15 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
