kroger
Hi I Farm Pro 2420 I need a fan belt but it want go pass the pulley and frame do I need to remove the pulley to put on the fan belt
Thanks
Thanks
I don't understand. After loosening the pivot bolt on the alternator, the belt should come loose from both pulleys. At that point you should be able to simply slip the belt over the fan blades. Depending upon how small the belt is, you might have to do it one blade at a time. But that's how it was put on there in the first place.it want go pass the pulley and frame
This will solve your problem. Vibration Free Link Belt It's better than a regular belt.
bigearl42 said:My belt broke today and it was shreaded does any know what lenght it is so i can go to a local auto parts and get one?
thanks
thanks
