bjr
My charging on the JM354 goes thru a 40 amp fuse and once in a while that blows. You might chech to see if there's a fuse in line. bjr
10 volts is inadequate - it takes 13.2 volts or better to overcome the resistance in a 12 volt battery to charge it. You could probably have a local alternator shop check out your alternator and tell you what it needs. I replaced mine with a 65-amp Delco 12Si internally regulated alternator as it was a direct drop-in swap and my voltage regulator was a constant problem. The new alternator allowed me to add work lights, which was big bonus.
A Delco rebuilt alternator will set you back $50 from Advance Auto with one of those 40% off coupons. I had to modify the existing bracket. Check my posting history for a thread with photos.
Whereas you can get a more analysis of your alternator performance at an auto electric shop, there's a simple field test that's actually easier to perform right at the battery. Put your meter leads on the + and - posts of the battery and note the voltage. Then have someone start the tractor while you watch the meter. A healthy alternator (and good wiring) should cause the meter to jump to about 14.5 volts DC. The difference between 1st and 2nd readings is the charging voltage provided by the alternator. Then as the battery accepts charge, the needle should slowly drop to between roughly 12.2 and 13.2 volts. That's the alternator putting out regular operating and "maintenance" voltage.I have the 3 wire alternator. What voltages am I supposed to get out of it?
That's reflecting battery discharge, which - if the ammeter doesn't return to center or above after the engine is running - almost inevitably means you've got an electrical short somewhere. You need to track that down before you proceed with the alternator output test.The amp meter was showing in the red which (less than 0). Does that mean it isnt putting out anything?
