Results 11 to 18 of 18
12-07-2012, 07:49 AM #11Super Member
- Join Date
- Dec 2003
- Posts
- 5,582
- Location
- Western Kentucky
- Tractor
- JD3720 Cab, 300X loader with 4-in-1 bucket
Re: Enfly
Don't have to know anything about Enfly to diagnose this one. The dealer was correct only to the extent that tractor wet disc brakes in fact ARE metal-on-metal. But what you describe sounds more to me like the throwout bearing was being ground away by the clutch release fingers. Once the heat and pressure of constant contact destroyed the bearing (and likely one or more of the fingers), no more clutch. Any "mechanic" that would work on the brakes to fix a clutch problem is in the wrong job.
First time tractor owners do have a tendency to ride the clutch while moving material - which WILL cause clutch damage in short order. But in this I'll tentatively give you benefit of doubt. As such, you didn't necessarily buy a lemon - as much as unfortunately buying from someone that (apparently) shouldn't be in the tractor business. Clutch adjustment is a significant item on the dealer prep list. It should have been done before you even took delivery. Unfortunately, there are still some cowboy "sellers" that do little more than open the crates and bolt the pieces together.
//greg//USN (Ret)
Former Chinese tractor owner (x4)
Current John Deere owner
12-09-2012, 01:21 AM #12Gold Member
- Join Date
- Aug 2009
- Posts
- 379
- Location
- Adelaide South Australia
- Tractor
- Foton FT404, International 444 with forklift, International B250, Kubota L2000DT, Truck converted to all terrain forklift and lots of other junk
Re: Enfly
Most state based Consumer affairs are real toothless tigers. Also they are reluctant to touch tractors saying that's a commercial transaction not a consumer one. (Been there done that). The only real way to go is to your states Administrative and Civil Tribunal. They will take action even across state borders. But as has been suggested forget phone calls the carry no legal weight. Email or write. Keep a record of everything. And as far as having an independent mechanic having a look at you tractor voiding your warranty that is rubbish. The dealer has to prove that the person you hired is incompetent. This was worked out on the case between Ford and Ultra tune......Ford lost the case as I'm sure your dealer would.
Sounds like the dealer is one of the fly by nighters that plague the Australian tractor industry. Good luck and I hope you can get things sorted out.
12-11-2012, 02:37 AM #13New Member
- Join Date
- Dec 2012
- Posts
- 4
- Location
- vic
- Tractor
- Enfly 55hp
Re: Enfly
Greg,
all I can Say; you sound like a very wise person, or maybe you have powers that can read my mind, of things that I have already thought?
Zonta,
Thanks
About the independent mechanic; if the tractor goes to an independent mechanic and gives a report on the things that still are not working (things that we had reported a year ago), what complications would have on the business? Therefore they will do anything to avoid of something like this happening.
Darby,
It is good that up to now you did not have any major problems and with some luck you might not have any in the future.
I do not want to disclose much information yet but I will post in the coming months the results.Last edited by tommi1; 12-11-2012 at 02:40 AM. Reason: spelling
12-11-2012, 02:53 AM #14New Member
- Join Date
- Dec 2012
- Posts
- 4
- Location
- vic
- Tractor
- Enfly 55hp
Re: Enfly
Does any one knows any places in melbourne that can inspect tractors or what is the best place to have a tractor inspected
01-03-2013, 07:11 PM #15New Member
- Join Date
- Dec 2012
- Posts
- 3
- Location
- Dural, NSW
- Tractor
- Enfly DQ404
Re: Enfly
Hi Tommy1
Sounds like you've (1) had some bad luck with your new tractor having a major component failure, and (2) been poorly treated by your supplier, who may not care too much about customer service. Unfortunately these two things often seem to go hand in hand, the end result being that you as the customer feel totally ripped off i.e. you've paid a large sum of money for a faulty product that the supplier doesn't want to fix unless you're willing to fork out even more money. Your comment "buying an Enfly is like gambling" is probably true, but I'm reminded of my brother's recent plight when he bought a late model top of the line Mercedes motor car for $85k, and 13 months later he had to replace the transmission at a cost of $14k..
My experience so far with an Enfly tractor is all good - I bought the 40hp model a while back, and it's been a great performer - I've put 40 hours on the clock, and keeps pulling out stumps, digging holes, moving heavy loads and anything else I ask of it....I've also had very good support from the Sydney supplier, so my impression of Enfly tractors is no doubt the opposite of yours....
01-06-2013, 07:27 AM #16Advertiser
- Join Date
- Sep 2010
- Posts
- 60
- Tractor
- jinma
Re: Enfly
Darby as you mentioned, there's a reason the Chinese made tractors are more affordable than others, the metal is not as hard as the higher priced units but if you have a good parts source, manuals and some mechanical knowledge and keep a check on things most blue collar folks like myself come out way ahead. The big name brands are very expensive compared to these units but the resale on the Chinese made tractors have really been surprising to us, they do pretty well if you keep them maintained and in good shape
Ben
Jinma Tractor Parts, Farm Pro Tractor Parts, Farmpro, Nortrack, Agracat
02-10-2013, 06:42 AM #17New Member
- Join Date
- Feb 2013
- Posts
- 1
- Location
- NSW
- Tractor
- None
Re: Enfly
Hi, looking at buying a tractor and read your post, just wanted to enquire is it still going well and are you still happy with it? Thanks heaps.
If anyone else has some recent feedback on the 40 and 55hp enflys that would be great!
Also has anyone had much to do with Blek, the Enfly dealer located at Penrith NSW?Last edited by Tarzac; 02-10-2013 at 03:56 PM.
02-16-2013, 02:31 AM #18New Member
- Join Date
- Feb 2013
- Posts
- 3
- Location
- Gundaroo NSW
- Tractor
- Enfly DQ404
Re: Enfly
How is the Enfly going? I am thinking about getting a DQ404, its mainly just for weekend use and I am happy to maintain it myself. Have you had any other issues with it?
Similar Threads
Enfly tractors - anyone know them?
By pipingmad in forum Chinese TractorsReplies: 3Last Post: 07-11-2010, 08:18 PM
