Page 10 of 12 FirstFirst ... 789101112 LastLast
Results 91 to 100 of 114
  1. #91
    Elite Member
    Join Date
    Sep 2009
    Posts
    3,184
    Murray, KY
    265 MF / JD 310B Backhoe
    Default Re: Nortrac / Yuchai Dozer questions...
    WOW I would say so.
  2. #92
    Veteran Member Bob Rooks's Avatar
    Join Date
    Feb 2007
    Posts
    1,798
    Bothell & Silverdale, WA
    '06 Yuchai YCT306-5A Bulldozer
    Refer to my post #74 re: steering clutches. You DID dodge a bullet.
    '06 Yuchai dozer, '00 Mustang 2040 skid steer, Litw BH7600 BH, Trimble equipped 7' Dual Dozer, and other sundry pull toys.
  3. #93
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    12,446
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Glad it all worked out that way for you. It could have cost you another $5000 real quick.
  4. #94
    Member
    Join Date
    Oct 2012
    Posts
    38
    Pakihi New Zealand
    YCT306S-S
    Hi a water temp gauge question The Bourdon Tube type gauge doesn't work on my YCT306S-S
    I am planning on replacing it with an electric one which I can set a warning light to come on at a set temperature what set point should I use? also planning on hooking up a low oil pressure light what pressure should it come on at?
    The motor in it is the three cylinder TY395 same as the Jimna 345 Tractor I think
  5. #95
    Join Date
    Feb 2007
    Posts
    1,798
    Quote Originally Posted by timbatrader View Post
    I set my Murphy Switchgage high temperature set point to 210 degrees. I'm also running a 180 degree thermostat. Even if you are using the original stock "ice cold" 140 degree thermostat, I'd still use 210 degrees.
    Low lube oil pressure set point is 10 psig.
  6. #96
    Member
    Join Date
    Oct 2012
    Posts
    38
    Pakihi New Zealand
    YCT306S-S
    Thanks Bob What the advantage of running a 180 degree thermostat? is it something you would recommend for everyone or is just for cold climates. Where I am in New Zealand is pretty temperate we do get down to about -3 celsius (I think thats about 26 in american speak) in mid winter and around 32 celsius in summer (90 odd Fahrenheit)
    Quote Originally Posted by Bob Rooks View Post
  7. #97
    Join Date
    Feb 2007
    Posts
    1,798
    Running the engine at 180 - 190 degrees is pretty much optimal for thermal effeciency of these engines (many new-tech diesels run at 190F - 200F degrees) which includes less soot build up in the lube oil and other components, more efficient lube oil performance, and much better fuel economy - to name a few.
    More here: Thermal efficiency - Wikipedia, the free encyclopedia
    Plus, there is improved thermal equilibrium of engine components - where the same ampunt of heat expands different materials at different rates to a maximum dimension or tolerance.
  8. #98
    Member
    Join Date
    Oct 2012
    Posts
    38
    Pakihi New Zealand
    YCT306S-S
    Broke a track shoe today not sure on the procedure to repair my plan is as follows any advise would be much appreciated
    1. Back off the track tension adjuster as much as possible
    2. Remove as long as length possible of track from the top by removing a track pin
    3. Place the removed track behind the dozer and just under the drive sprocket
    4. Drive/winch the dozer backwards onto the track
    5. Join both sections of track together
    6. Join the ends together and insert the replacement shoe making the joint with both ends half wrapped around the drive sprocket
    7. Adjust the track tension back to the correct tension
    I am not looking forward to putting the final pin in any tips where to position it and or how get the two ends together to get the pin in would be appreciated
    http://i1262.photobucket.com/albums/...r/IMG_0615.jpg
    http://i1262.photobucket.com/albums/...r/IMG_0613.jpg
    Nortrac / Yuchai Dozer questions...-img_0615.jpgNortrac / Yuchai Dozer questions...-img_0612.jpg
  9. #99
    Elite Member
    Join Date
    Sep 2009
    Posts
    3,184
    Murray, KY
    timbatrader just from the one photo I might just try to fix it without moving the machine or track more than enough to be able to repin from the bottom side by driving wedged shape timbers to force the link connection to line up using a drift punch?
    are the black places defective places in the link? Did something get under that link or was it was torque pressure from braking/turning.
    Do you have access to a backhoe?
    How do you rate the under carriage? 100%, 50%, etc?
  10. #100
    Join Date
    Feb 2007
    Posts
    1,798
    Two heavy duty C-clamps (four total) on each side of the shoe at the free ends of the track holding a short piece of chain between them. Run a come-a-long between the chains on each track end and draw them together. You will probably have to depress the right steering clutch so the sprocket wil turn. I remember doing that stuff on D8's way back in the woods - back in the day. Blocking the dozer up will be a great help, but so far you've got the right plan going. Good luck.
    That shoe edge is bent pretty badly, just what are you doing anyway? You have to remember that these are lightweight machines, so don't treat them like they are a D8 - they're not.
Similar Threads
  1. Yuchai dozer thread?
    By Bob Rooks in forum Chinese Tractors
    Last Post: 04-26-2013, 05:28 PM
  2. nortrac dozer
    By jpo in forum Parts/Repairs
    Last Post: 09-06-2011, 05:51 PM
  3. Dealer Any yuchai dozer dealers in CA
    By hondarider in forum Chinese Tractors
    Last Post: 08-14-2009, 06:47 AM
  4. What do you figure a Nortrac/Yuchai 30HP Dozer can do better than a BX24?
    By montelatici in forum Kubota Owning/Operating
    Last Post: 04-16-2007, 09:48 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
