Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Join Date
    Dec 2006
    Posts
    1,520
    Coastal Rhode Island
    Jinma 354, purchased 2007
    Default Power steering hydraulic fitting ID
    Does anyone know what kind of fitting is on the end of the power steering outlet hose on a Jinma 354? This is the hose I'm talking about:
    Outlet pipe II
    One end has a 90-degree male threaded pipe that goes into a banjo fitting on the priority valve. It's the other end I'm interested in. It's a female threaded fitting, I don't know how to ID it.
    Alternately, does anyone know the diameter of that hose?
    The background: I want to add remote hydraulics to my tractor. I need a hydraulic return line for that. My hydraulic tank only has one opening, which is the return pipe from the power steering. That's a hard pipe and I don't feel like cutting it. At the tank there's no possibility of teeing in because the connection is right behind the 3-point hitch control. The other end is at the priority valve and there is no room to tee because the FEL bracket is right up against it. The return from the power steering is a hose running from the steering box to the priority valve. It seems my best bets are either to put a tee between the steering box and the hose, or to cut the hose and put in a barbed tee.
    To put a tee on the end of the hose I need to know what kind of fitting it is. To cut the hose i need to know the hose diameter.
    Any advice is appreciated.
    Thanks.
  2. #2
    Advertiser
    Join Date
    Mar 2004
    Posts
    1,466
    Texas
    Default Re: Power steering hydraulic fitting ID
    I think it's a 18mm ORFS O-ring Face seal, if you will call the shop we can try to help you 979-865-4002, however I know these fittings are a pain in the A ** to cross
    Tommy
    Affordable Tractor Sales
    "Your Jinma Parts Superstore"
    Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
  3. #3
    Join Date
    Dec 2006
    Posts
    1,520
    Thanks Tommy.
    I did some quick googling on ORFS metric fittings and what I learned was enough to scare me away. So now I'm thinking I have three options: cut and tee into the hose between the steering box the priority valve, cut and tee into the pipe between the priority valve and the hydraulic tank, or drill and tap into the hydraulic tank.
    None of the three seem particularly easy. Anybody have any thoughts?
    Thanks.
  4. #4
    R.I.P.
    Join Date
    Dec 2008
    Posts
    5,883
    North Carolina
    Kubota BX2200
    Quote Originally Posted by quicksandfarmer View Post
    Thanks Tommy.
    Thanks.
    Is the hose size common and known? If so, I'd see if there are reusable fittings for that size and go that route.
    But if not, I'd drill the top, unless:
    On my tractor, I have a quick connect that comes out the back that was supposed to handle a dump trailer. But, on the opposite side of that QD, there is a pipe that is to allow draining the hydraulic fluid out of the lift body (for fluid changes). If I had to do it, I'd use that on my tractor. So, it begs the question...can the drain for your lift body (even if it is different than mine) be pressed into service for your task?
  5. #5
    Join Date
    Dec 2006
    Posts
    1,520
    Quote Originally Posted by EE_Bota View Post
    I have looked and looked and cannot find a drain on my hydraulic tank. I agree that would be easiest. I'm not saying it's not there, I just can't find it.
  6. #6
    R.I.P.
    Join Date
    Dec 2008
    Posts
    5,883
    North Carolina
    Kubota BX2200
    Mine is a Farmpro, year on fender 2004. It is supposed to be like a 304. The drain pipe on mine originates at the right rear of the lift box at the very bottom. I'm sure if your's were in the same place, you'd find it.
    If mine didn't have a drain, and I wanted a new entrance, I'd be tempted to make a drain if the setup made me feel I could pull it off without ruining anything.
  7. #7
    Super Member greg_g's Avatar
    Join Date
    Dec 2003
    Posts
    6,086
    Western Kentucky
    JD3720 Cab, 300X loader with 4-in-1 bucket
    The drain on my JM254 was at the rear of the lift box, hopefully yours is the same. Look above and to the left of the PTO shaft. There's one hex head that looks out of place. That should be the hydraulic sump drain.
    Can't remember with my Jinmas, but here's a photo of how to connect additional hydraulics to my TS354C. Haven't seen fittings like these - the gold colored ones - on mainstream tractors. So if your Jinma has locations to which they can be installed, you'll almost certainly have to get them from a Chinese tractor dealer.
    //greg//
    Attached Thumbnails Attached Thumbnails Power steering hydraulic fitting ID-cimg0005-jpg
    USN (Ret)
    Former Chinese tractor owner (x4)
    Current John Deere owner
  8. #8
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Can you retap the fill/vent port to take a "T"? This will allow you to still have a fill/vent and use the other leg of the "T" to install your new return.
    Chris
  9. #9
    Join Date
    Dec 2006
    Posts
    1,520
    I'll take a look, but the fill/vent is under the seat, I have to slide the seat forward to check the level. I'm not sure I can fit a tee in there.
  10. #10
    Gold Member Smalljobs's Avatar
    Join Date
    Mar 2009
    Posts
    327
    Massachusetts
    Jinma 284
    I added rear and front remotes to my Jinma 284. Attached is a photo of the drain. I put an NPT cross on the existing return line. It was already NPT so I just added more off the shelf connections.
    Power steering hydraulic fitting ID-return-jpg
    Steve Anderson
    Jinma 284LE w/Creeper/Koyker 160 Loader/Markham Toothbar, Frame mounted HWO4X backhoe, 64" John Deere 3 PH Snow blower,3 PH splitter, Bro-Tek thumb, Jinma 8" chipper, Loader mounted Meyer plow
Similar Threads
  1. fitting power assisted steering to w9
    By interw9 in forum Projects
    Last Post: 02-18-2013, 05:09 AM
  2. Hydraulic Power steering problem
    By Prankstar in forum Hydraulics
    Last Post: 02-18-2011, 02:07 AM
  3. hydraulic power steering, or assisted pwr steering
    By RaymondTM in forum Parts/Repairs
    Last Post: 07-29-2010, 12:23 PM
  4. JD 4710 Power Steering/Hydraulic Fluid
    By mitchdb in forum John Deere Owning/Operating
    Last Post: 02-28-2005, 06:04 PM
  5. Power Steering Hydraulic FIXED
    By DennisArrow in forum Iseki
    Last Post: 07-04-2003, 10:21 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
