Results 1 to 10 of 11
10-04-2012, 12:27 PM #1Silver Member
- Join Date
- Jul 2004
- Posts
- 116
- Location
- Lady Lake, Fl.
- Tractor
- Jinma 284
Fuse Replacment
I want to replace the fuses on my 2002 284 Jinma. The fuse box lays flat on top and has 5 fuses. When I stand on the side of the tractor that has the fuel lines I read the fuse sizes as follows: 1. no size 2. no size 3. 10 amp 4. 20 amp 5. 30 amp. Anyone know what size 1 and 2 would be? Thanks Pat
10-04-2012, 02:43 PM #2Super Member
- Join Date
- Dec 2003
- Posts
- 5,587
- Location
- Western Kentucky
- Tractor
- JD3720 Cab, 300X loader with 4-in-1 bucket
Re: Fuse Replacment
Spare fuse holders
//greg//USN (Ret)
Former Chinese tractor owner (x4)
Current John Deere owner
10-05-2012, 07:23 PM #3Silver Member
- Join Date
- Jul 2004
- Posts
- 116
- Location
- Lady Lake, Fl.
- Tractor
- Jinma 284
Re: Fuse Replacment
The Bussman fuses that I purchased are a little too wide to plug in, should I file them down a little to get them in?
10-06-2012, 10:43 AM #4Super Member
- Join Date
- Dec 2003
- Posts
- 5,587
- Location
- Western Kentucky
- Tractor
Re: Fuse Replacment
USN (Ret)
10-06-2012, 07:45 PM #5Silver Member
- Join Date
- Jul 2004
- Posts
- 116
- Location
- Lady Lake, Fl.
- Tractor
- Jinma 284
Re: Fuse Replacment
ATV style is too small. The closest was MAX. I may have to replace the fuse box but I think I will try filing a little off the outside edge of both prongs and see what happens. Pat
10-06-2012, 09:46 PM #6
10-07-2012, 01:27 AM #7Platinum Member
- Join Date
- Nov 2008
- Posts
- 557
- Location
- US Virgin Islands
- Tractor
- Jinma JM304
Re: Fuse Replacment
Yes, automotive fuses are one thing has become almost universally standardized. There are the three sizes of blade fuses and then three or four sizes of circuit breakers. The circuit breakers use a standardized contact configuration, too. Much better than the way things were a few decades ago.
10-07-2012, 11:10 AM #8Silver Member
- Join Date
- Jul 2004
- Posts
- 116
- Location
- Lady Lake, Fl.
- Tractor
- Jinma 284
Re: Fuse Replacment
My bad, I meant to type ATC. The width of ATC prongs from one side to the other is 7/16th. The width between the prong holders on my 2002 is 6/16th. These are the really old fuses that came on the 2002 Jinma. I'll let you know if filing off a little on each prong works. Pat
10-08-2012, 06:18 AM #9Approved Advertiser
- Join Date
- Mar 2004
- Posts
- 1,117
- Location
- Texas
Re: Fuse Replacment
On the 2002 models, they still used the wire wrapped fuses, I don't think the ATC fuses will stay tight in that box,I still have some of those fuse boxs and fuses.Is the fuse box about 2" x 3" square, with a clear plastic top ?
Tommy
Affordable Tractor Sales
"Your Jinma Parts Superstore"
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
10-08-2012, 07:59 AM #10Super Member
- Join Date
- Dec 2003
- Posts
- 5,587
- Location
- Western Kentucky
- Tractor
Re: Fuse Replacment
Yeah, ATC is the wrong size fuse for that tractor. If you look at that diagram I provided above, you'll see the blade width of an ATC is 14.2mm. That converts to 0.55 inch. Your stated "6/16th" is only 0.375" inch. Folks with that size fuse had two choices; replace the fuse box and fuses with aftermarket ATC, or buy fuse wire. My Jinmas and my TaiShan used ATCs, but my KAMA used fuse wire, and I don't own any of them anymore. So I have plenty of extra fuse wire if you'd prefer to simply re-wrap your fuses.
//greg//USN (Ret)
Similar Threads
ignition switch replacment
By Smoody in forum YanmarReplies: 14Last Post: 01-22-2012, 02:28 AM -
Fuse box/ fuse issue (820)
By BadAssRX7 in forum John Deere Ag TractorsReplies: 10Last Post: 03-19-2011, 04:21 AM -
replacment disc's
By seedman4 in forum Ag Tractors & MachineryReplies: 2Last Post: 02-06-2008, 07:56 PM -
Looking for Replacment Relay
By ktate2002 in forum Kubota Owning/OperatingReplies: 3Last Post: 05-14-2006, 10:43 PM -
NH replacment filters for Kubota
By jimg in forum Kubota Owning/OperatingReplies: 6Last Post: 02-11-2004, 02:01 AM
