Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    New Member
    Join Date
    Oct 2012
    Posts
    1
    el paso tx
    farmpro 2425
    Default Farm Pro Manuals??
    Are there any service manuals available for the Farm Pro 2425 tractor??
  2. #2
    Approved Advertiser
    Join Date
    Mar 2004
    Posts
    1,117
    Texas
    Default Re: Farm Pro Manuals??
    No service manuals just parts and operation. Do you have those ? If not we have them seperate or in sets ,if you need a set you need to confirm which engine you have. If you need some help with repairing your tractor you can give us a call we will be glad to help.Your Farmpro tractor is the same as the Jinma 254 tractors
    Tommy
    Affordable Tractor Sales
    "Your Jinma Parts Superstore"
    Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
  3. #3
    New Member
    Join Date
    Oct 2012
    Posts
    7
    West Plains MO
    Farm Pro 2425 and 1953 Ford 8-N
    I just purchased a Farm Pro 2425 tractor. It being the same as Jinma explains some of the diagrams and part numbers in my operation manual. I am having electrical problems. No gauges. Checked all the fuses in the fuseblock, but haven't searched for in-line fuses yet. I wouldn't think one fuse could power all the different gauges and idiot lights too. First owner said he knocked off the exaust pipe and had to replace it. Maybe too much heat on the fuseblock?
  4. #4
    Super Member greg_g's Avatar
    Join Date
    Dec 2003
    Posts
    5,587
    Western Kentucky
    JD3720 Cab, 300X loader with 4-in-1 bucket
    Unless you see a physical distortion of the fuse block, I doubt exhaust heat has anything to do with it. Cheap electrical systems are almost universal with entry level Chinese tractors. But your manual should have had a wiring diagram. When you find it, you'll likely see that - with the exception of the ammeter - all other gauges/indicators are protected by a common fuse.
    //greg//
    USN (Ret)
    Former Chinese tractor owner (x4)
    Current John Deere owner
  5. #5
    New Member
    Join Date
    Oct 2012
    Posts
    7
    West Plains MO
    The wiring diagram is very vague about what does what. When the wire lines get to the fuseblock area they blend together, not a high quality drawing.
  6. #6
    Join Date
    Dec 2003
    Posts
    5,587
    Western Kentucky
    What model year is this FarmPro, and which engine? Please refer to the engine label and the chassis label. Engine label is typically either on the valve cover or on the side of the engine block. Chassis label is typically either inside one of the rear fenders or on the transmission housing.
    //greg//
    USN (Ret)
  7. #7
    Approved Advertiser
    Join Date
    Mar 2004
    Posts
    1,117
    Texas
    See if this helps you any, it may be a little clearer for you
    Tommy
    Attached Thumbnails Attached Thumbnails Farm Pro Manuals??-diagram-2430-farmpro-2420.jpg
  8. #8
    New Member
    Join Date
    Oct 2012
    Posts
    7
    West Plains MO
    Thanks for the wiring diagram. With it on my computer I can enlarge it big enough to see where things go. This helps alot.
  9. #9
    New Member
    Join Date
    Oct 2012
    Posts
    7
    West Plains MO
    It is a Farm Pro 2425 date 2006 01
    Engine ID Yangdong Y385T date 2005 12
  10. #10
    Join Date
    Dec 2003
    Posts
    5,587
    Western Kentucky
    Thanks. That diagram Tommy uploaded is basically representative, but it's for an earlier model with the individual gauges. Now that he knows it's for a 2006, perhaps he's got access to a newer diagram that incorporates the cluster gauge wiring - because unfortunately I don't. There is however a problem with how the above diagram depicts the tach/hour meter wiring. Look at the K terminal on tachometer sender 21. The line going down to that tail light wire is incorrect. That wire is the hour meter trigger, and should go over to oil pressure sender 24.
    //greg//
    USN (Ret)
Similar Threads
  1. Operating manuals farm pro 2430
    By mrtool033 in forum Owning/Operating
    Last Post: 01-05-2012, 07:25 AM
  2. Better manuals for Farm Pro tractor
    By bigcountry1009 in forum Chinese Tractors
    Last Post: 04-18-2007, 11:15 AM
  3. FARM PRO
    By bigtrooper in forum Chinese Tractors
    Last Post: 05-16-2005, 11:03 PM
  4. Jimna, Farm Pro, Farm King-what's the difference
    By theoldpioneer in forum Chinese Tractors
    Last Post: 11-29-2004, 08:50 AM
  5. Pro Farm
    By KevinCarty22 in forum Chinese Tractors
    Last Post: 11-06-2004, 09:51 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
