Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    New Member
    Join Date
    Jan 2013
    Posts
    7
    Giscome, British Columbia
    Jinma 284
    Default Front blade on Jinma 284
    I currently use a FEL and a rear blade for my snow clearing, and have found I don't care for the krick I keep getting in my neck when blading snow around. I found a picture of this rig and wonder if anyone has experience using anything like this on their 284??
    It looks like it would be easy to attach/remove from the front bucket.
  2. #2
    Super Star Member Thomas's Avatar
    Join Date
    Apr 2000
    Posts
    11,418
    Lebanon,NH.
    Kubota L2800HST w/Frontloader & CC 2042
    Default Re: Front blade on Jinma 284
    I can't see if any trip springs..trip springs can save you from damage.
  3. #3
    Veteran Member Bob Rooks's Avatar
    Join Date
    Feb 2007
    Posts
    1,803
    Bothell & Silverdale, WA
    '06 Yuchai YCT306-5A Bulldozer
    Like Thomas said: No trip springs? Better wear your seat belt and have it snugged up.
    '06 Yuchai dozer, '00 Mustang 2040 skid steer, Litw BH7600 BH, Trimble equipped 7' Dual Dozer, and other sundry pull toys.
  4. #4
    Elite Member RonMar's Avatar
    Join Date
    May 2005
    Posts
    2,607
    Port Angeles WA
    Jinma 284 delivered 06/28/05
    I know one participant here has a snowplow out on the FEL. No kick springs means the loader arms will be absorbing any sudden stops like when hitting a curb. That could mean some expensive repairs... I see issues when angling the plow. With the plow out on such a long moment arm, I could see it fairly easilly exceeding the front traction and wanting to push the tractor to the side. If I recall though, he said it really works well. If you have a LOT of snow, being able to push snow up and over existing banks can be real handy...
    Ron
  5. #5
    Gold Member TTTTTT's Avatar
    Join Date
    Mar 2008
    Posts
    251
    Ajax, Ontario
    Dong Feng 354 (Oct 2008)
    It all depends on he type of drive you are plowing. If it is a smooth paved drive with known issues you will probably be ok. The drive I plow is a cottage gravel dirt road with many up and downs, tree roots rocks etc. I have an 8' all steel plow ( very heavy) I modified for my loader ( minus the bucket). It has 4 large springs. I also added front remotes for controlling the blade angle. I also added a cross over relief valve. Every so often I catch an edge and the relief kicks in. The springs also are constantly being used. It works really well. But that of course opens up the plow vs blowing snow debate. If you have the room to plow it, it is faster. As mentioned having it on the FEL you can push pile high and back as well
    Heres the thread with the details
    http://www.tractorbynet.com/forums/h...ow-hookup.html
    Hope it helps Dave
    DF-354 (Oct.2008), Town Sunny 404 Loader,
    Town Sunny 3pt BH -6',
    3pt Log Splitter - 26",
    3pt 12" PHD
    8' Snow Plow Blade adapted to FEL,
    3 pt 7' Rear Blade,
    FEL / 3pt Forks,
    Hydraulic Toplink.
    3pt Hydraulic Crane
  6. #6
    Elite Member
    Join Date
    Apr 2009
    Posts
    3,202
    adirondacks
    I used a plow on my jinma 254 worked waaaaayyy better then the FEL, but it did have the spring trip which I STRONGLY suggest is needed
  7. #7
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    12,460
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Default
    I also have a plow. It mounts in place of my FEL and is 7' wide. I control the angle with my rear remote. Works great. Like the others said, the lack of trip springs would concern me.
    Chris
  8. #8
    New Member
    Join Date
    Jan 2013
    Posts
    7
    Jinma 284
    Thanks for the replies, it sounds like if I decide to go this way I better look for one with trip springs.....
  9. #9
    Join Date
    Dec 2007
    Posts
    1,456
    Eastern Ontario
    Jinma 284(Spirit fel), MF 135 (MF200 fel)
    A company called Worksaver sell a clamp on blade through Farmfleet (and one fabbed to fit the loader) for less than $2000 here in Canada. They all have trip springs and the one to fit the FEL has hydraulics. Not sure which loader you have but you might be able to get one to fit. Still not cheap but depends on how badly you want to drive forward
    http://www.farmfleet.com/WinterFlyer2012.pdf (see page 3)
    When the snow is not that deep I use a rear blade and drive over the snow. Deeper stuff I use a blower
  10. #10
    Gold Member Smalljobs's Avatar
    Join Date
    Mar 2009
    Posts
    270
    Massachusetts
    Jinma 284
    How about one of these. I made it myself. I think it's best if blade is as close as possible to the tractor and that means removing the bucket.
    Front blade on Jinma 284-feb2011-snow.jpgFront blade on Jinma 284-finally-done.jpg
    Steve Anderson
    Jinma 284LE w/Creeper/Koyker 160 Loader/Markham Toothbar, Frame mounted HWO4X backhoe, 3 PH splitter, Bro-Tek thumb, Jinma 8" chipper, Loader mounted Meyer plow
Similar Threads
  1. Jinma 284 Front Axle
    By Pcanter in forum Parts/Repairs
    Last Post: 11-13-2011, 02:52 PM
  2. Jinma 284
    By rrobnshell2 in forum Parts/Repairs
    Last Post: 07-17-2010, 03:35 PM
  3. Jinma 284
    By meporsche in forum Chinese Tractors
    Last Post: 11-12-2009, 01:21 PM
  4. Box Scraper 5' Box Blade Install on Jinma 284 (or, related type units)
    By idaho3748 in forum Attachments
    Last Post: 11-06-2006, 01:24 PM
  5. Jinma 284
    By Redfisher in forum Chinese Tractors
    Last Post: 03-27-2002, 10:14 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
