Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    Feb 2013
    Posts
    3
    hagar
    foton 254
    Default 2007 foton 254
    tractor wont turn over with key? i disconected saftey switch for clutch also check all fuses. I can use a screwdriver to start tractor when screwdriver touches starter so battery is good ? so when i try to start with key i preheat that works then turn more for start and nothing ? i also changed a few fuses just to make sure 30 amps. any suggestions?
  2. #2
    Join Date
    Nov 2008
    Posts
    557
    US Virgin Islands
    Jinma JM304
    Default Re: 2007 foton 254
    YOu said you disconnected the clutch switch? That switch is a normally open switch that pressing the clutch pedal down closes, completing the circuit to the starter solenoid. If you disconnect it, you have to short the two wires together to complete the key switch circuit for starting.
  3. #3
    New Member
    Join Date
    Feb 2013
    Posts
    3
    hagar
    foton 254
    Quote Originally Posted by Rich Waugh View Post
    thks will try that
  4. #4
    Advertiser
    Join Date
    Sep 2010
    Posts
    60
    jinma
    Sounds, like your solinoid may be bad if it starts with a screwdriver after shorting the two lugs on solinoid. Connect your clutch switch back and if it still does the same thing I expect its your solinoid. We have plenty in stock.
    Ben
    Circle G Tractor Sales, Inc.
    Jinma Tractor Parts, Farm Pro Tractor Parts, Farmpro, Nortrack, Agracat
    662-252-5272
  5. #5
    New Member
    Join Date
    Feb 2013
    Posts
    3
    hagar
    foton 254
    It worked I connected a wire together and it works thks again !
  6. #6
    Advertiser
    Join Date
    Sep 2010
    Posts
    60
    jinma
    Glad you got it going again. Let us know if you need anything.
    Ben
Similar Threads
  1. Tractor Sizing Foton 254
    By 13gef13 in forum Chinese Tractors
    Last Post: 12-31-2012, 04:47 PM
  2. Trans leaking 254 Foton
    By valley in forum Chinese Tractors
    Last Post: 09-29-2012, 12:21 PM
  3. Foton 254 overheating.....in an odd way.
    By amafrank in forum Chinese Tractors
    Last Post: 08-24-2012, 08:18 PM
  4. Foton 254 starting problem
    By succor in forum Chinese Tractors
    Last Post: 08-08-2011, 08:42 PM
  5. Foton 254 priority valve
    Last Post: 01-23-2009, 09:05 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
