Results 1 to 8 of 8
  1. #1
    Gold Member sd455dan's Avatar
    Join Date
    Oct 2012
    Posts
    358
    North Idaho
    Ford 3000-Rhino 554,Co-Op ,Honda ,Gilson riding mowers
    Default Anyone modified a leak down tester for diagnosing a cylinder on their diesel tractor?
    I just finished checking the leakage on my Rhino 554 rockshaft after honing and replacing the seal. It got me thinking- that if if I just made an adapter, for this inexpensive leak down tester to replace the injector, I could trouble shoot my tractor diesels. Anyone already done this and if so how well did it work?Anyone modified a leak down tester for diagnosing a cylinder on their diesel tractor?-rockshaft-leakdown-test-002.jpg
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2
    Veteran Member Bob Rooks's Avatar
    Join Date
    Feb 2007
    Posts
    1,845
    Bothell & Silverdale, WA
    '06 Yuchai YCT306-5A Bulldozer
    Default Re: Anyone modified a leak down tester for diagnosing a cylinder on their diesel trac
    I would assume it would work very well because that's what is in my kit (for other engines). I have made an adapter from a glow plug and also taken firing pressures, however this is not for the novice.
    What seal did you replace and hone? Curious.
    '06 Yuchai dozer, '00 Mustang 2040 skid steer, Litw BH7600 BH, Trimble equipped 7' Dual Dozer, and other sundry pull toys.
  4. #3
    Join Date
    Oct 2012
    Posts
    358
    North Idaho
    I should have worded that -after honing the rockshaft cylinder, due to some small scoring and replacing the worn out and disintegrated hydraulic seal with a new one.
    Sorry about the confusion, maybe someone knows of a good source of a reasonably priced adapter to replace the injector with?
    Hope no one would actually hone a hydraulic seal...
  5. #4
    Join Date
    Feb 2007
    Posts
    1,845
    I guess I should have been more clear also. Yes, you can make an adapter from an old injector, it's relatively simple, however, the injector won't be able to be used for fuel anymore. Disassemble and remove the pintle and seat assembly, put a bolt and copper sealing washer where the fuel leak off line attaches, then fit an air chuck nipple or other adapter that's compatible with your tester where the fuel line attaches. I don't know what type/make/size of engine you have, or the injector type, so those instructions are pretty generic.
  6. #5
    Join Date
    Oct 2012
    Posts
    358
    North Idaho
    Thanks Bob , I just installed a new injector on the Rhino-compared the spray pattern on new and old injector and they both atomized well and had a conical pattern.I had assumed the Rhinos injector had at least 2 spray nozzle holes like my Ford tractor and thought one was plugged. and so I ordered a new one. Well it runs the same, slight miss at idle and a little tinge of blue smoke. Anyway the 2 injectors are both good so I didn't want to use a good injector for a tester. I threw this together tonight, not very high tech but I will give it a try, Anyone modified a leak down tester for diagnosing a cylinder on their diesel tractor?-homemade-injector-leakdown-test-fitting The injector on the left is for the Rhino/Shanghai and the right one is for a Ford 3000 ,actually fairly similar...
  7. #6
    Join Date
    Feb 2007
    Posts
    1,845
    Quote Originally Posted by sd455dan View Post
    Thanks Bob , I just installed a new injector on the Rhino-compared the spray pattern on new and old injector and they both atomized well and had a conical pattern.I had assumed the Rhinos injector had at least 2 spray nozzle holes like my Ford tractor and thought one was plugged. and so I ordered a new one. Well it runs the same, slight miss at idle and a little tinge of blue smoke. Anyway the 2 injectors are both good so I didn't want to use a good injector for a tester. I threw this together tonight, not very high tech but I will give it a try, Click image for larger version.
Name:	homemade injector leakdown test fitting 003.jpg
ID:	305233 The injector on the left is for the Rhino/Shanghai and the right one is for a Ford 3000 ,actually fairly similar...
    Nice job, pretty clever. Looks like you used a tire chuck.
  8. #7
    Join Date
    Oct 2012
    Posts
    358
    North Idaho
    Thanks Bob, after looking at the similar thread under this one- Diesel Compression Tester for Yanmar 3TNE88, I had sticker shock , looked through some odds and ends in the garage, and when I saw that old tire chuck figured why not just cut off the non pipe thread end,run a die over it to give it some adjustability, and allow a 90 degree male quick connect to be twisted on the end before tightening the steel plate down, because its pretty tight up under the fuel tank. The part that took the most thought was the seal , which is an inverted grommet over a 3/8 " Quadrajet fuel line end pressed into the pipe fitting. The flare and seal are larger than the regular injector needle valve body so there shouldn't be any danger of losing it into the cylinder. I believe it should also work for the Ford 3000. Here's a shot of some of the original parts , If it works - great, if not its back to the drawing boardAnyone modified a leak down tester for diagnosing a cylinder on their diesel tractor?-homemade-injector-leakdown-test-fitting
  9. #8
    Join Date
    Feb 2007
    Posts
    1,845
    That should work great. I see no problems using it for leak-down testing. Compression testing is another story though. Nice work.
Similar Threads
  1. Diesel Compression Tester for Yanmar 3TNE88
    By Mechanos in forum Parts/Repairs
    Last Post: 03-04-2013, 11:43 AM
  2. Propane powered Ford Tractor - authentic or modified
    By kquinton in forum General Vintage Tractors
    Last Post: 07-05-2012, 10:31 PM
  3. Need Help Diagnosing Tire Problem
    By Owenslee in forum Kubota Owning/Operating
    Last Post: 08-03-2011, 10:48 AM
  4. Pics of my father's modified diesel RTV...
    By kubota orange in forum ATVs & Utility Vehicles
    Last Post: 09-19-2008, 12:03 AM
  5. Resale of modified ROPS tractor
    By JerryG in forum Buying/Pricing/Comparisons
    Last Post: 01-26-2005, 09:32 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
