Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 57
  1. #31
    Advertiser
    Join Date
    Mar 2004
    Posts
    1,457
    Texas
    Default Re: 2007 Jinma 284 (iron horse) will not start
    You have a head gasket problem for sure, I would also give the head a good look over once its off,You have the Quanchai Engine ? Reguardless we have that head gasket and water pump gasket. Also you do not want to run it without a thermostat
    Tommy
    Affordable Tractor Sales
    "Your Jinma Parts Superstore"
    Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
  2. #32
    Bronze Member chris85's Avatar
    Join Date
    Jan 2012
    Posts
    63
    Massachusetts
    JM 284
    yes it has the Quanchai Engine, I'm the guy who just ordered the glow plugs, and the water pump a couple month back from you. I see in the string of replies there is mention of a valve adjustment, is this a complicated thing? Are there any other parts you may guess I will need besides the two gaskets and thermostat?
    Chris
    Massachusetts
    "Iron Horse" JM 284 Tractor w/ HW03 backhoe, “homemade” 28 ton, hydraulic log splitter (thanks to Northern tool and Tractor Supply), Craftsman 42 lawn tractor, Craftsman snow blower.
  3. #33
    Advertiser
    Join Date
    Mar 2004
    Posts
    1,457
    Texas
    We can give you the valve adjustment specs, those 2- gaskets should take care of it unless you need radiator hoses too
    Tommy
  4. #34
    Join Date
    Nov 2008
    Posts
    802
    US Virgin Islands
    Jinma JM304
    The valve adjustment is not complicated, it just takes a hour or so of careful work with a wrench and a couple of feeler gauges. The procedure has been detailed a few times on this site elsewhere, you can search for it.
  5. #35
    Join Date
    Jan 2012
    Posts
    63
    Massachusetts
    JM 284
    Started to pull the head yesterday, 2007 Jinma 284 (iron horse) will not start-tractor-jpg2007 Jinma 284 (iron horse) will not start-valves-jpg2007 Jinma 284 (iron horse) will not start-cover-jpg was surprised to find a "pudding like" goop covering everything.
    Chris
    Massachusetts
  6. #36
    Join Date
    Nov 2008
    Posts
    802
    US Virgin Islands
    Jinma JM304
    No surprise there, that's oil and coolant mixed together and cooked. You're going to need to drain the oil and the coolant from the block and radiator and clean them out before you run the engine again. You can start by pulling the drain bung in the oil sump and flushing lots of diesel fuel through there until it runs clean. That isn't going to get all the oil galleys clean though, so you'll have to do the same thing again after the engine is reassembled and pump it through by cranking the engine a long time with the compression release pulled or the glow plugs or injectors removed. I'd add a bit of alcohol to the diesel to help absorb the water. It may take a few of those flushes to get all the crud out of the oil galleys but it is well worth doing. Take the radiator to a shop to have it boiled out.
  7. #37
    Join Date
    Jan 2012
    Posts
    63
    Massachusetts
    JM 284
    Default
    The gasket had no visible sign of blow-by. I'm going to have a local shop test the head for warping or cracking, couldn't see any by eye.
    Chris
    Massachusetts
  8. #38
    Elite Member
    Join Date
    Feb 2007
    Posts
    2,843
    Earth
    A yellow one
    Quote Originally Posted by chris85 View Post
    That emulsion is common to coolant leaking into the lube oil system or poor crankcase ventilation. Check to see that your evacuation system isn't plugged. If you find there isn't any problem with the cylinder head then you may have failed cylinder liner O-ring seals, or worse yet, a cracked liner.
  9. #39
    Gold Member BuilderML's Avatar
    Join Date
    Nov 2012
    Posts
    479
    Tolland, CT
    CCY SX3100
    Chris85,
    Did you buy this unit off of craigslist? I was going to say that i would send the head off to a local machine shop "napa" and have them look the head over. Its off nows the time to do it. When i use to work in a garage and we did head gaskets on cars/turck the head would always get sent out. Yet when you go to the dealer they just do what we called a lift and tuck. Just lift the head and replace the gasket and put it back together.
  10. #40
    Join Date
    Jan 2012
    Posts
    63
    Massachusetts
    JM 284
    Quote Originally Posted by BuilderML View Post
    Chris85,
    Yes, found on CL a year ago, from a guy in Salisbury just on the NH line.
    There is a shop in Southboro Ma that will inspect and conduct a test on it to see if it is warped or damaged.
    Chris
    Massachusetts
Similar Threads
  1. Jinma 284 won't start
    By carnut66 in forum Chinese Tractors
    Last Post: 08-30-2010, 03:00 PM
  2. 2007 Jinma 284 No Start
    By HitnMiss in forum Chinese Tractors
    Last Post: 08-08-2010, 10:03 AM
  3. Jinma 284 won't start
    By meporsche in forum Chinese Tractors
    Last Post: 12-08-2009, 08:17 PM
  4. Iron Horse (Jinma 254) Brake question.
    By jgl1962 in forum Chinese Tractors
    Last Post: 11-24-2008, 10:21 PM
  5. Iron Horse (Jinma) 254 questions
    Last Post: 07-09-2008, 11:52 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
