Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Member
    Join Date
    Apr 2011
    Posts
    25
    McRae Ga
    285 MF and 284 Farm Boss and D31 Komatsu
    Default Jinma 284 PTO HP for a finish mower
    I have been using a bush hog 72 in finish mower. I got it out today started getting in ready for the summer. After greasing everything I engaged the PTO , noticed a lot of noise. I need to replace both idler pulleys and two spindle bearings and a belt.
    I have a friend of mine that bought a zero turn lawn mower and no longer needs the finish mower he has. It is a Caroni 93in. It is 3 years old and used very little. I can get it for 1000. Will it be to large for the tractor and will it fit properly? I have about 5 acres of grass.
  2. #2
    Super Member SPIKER's Avatar
    Join Date
    Jun 2002
    Posts
    5,000
    Ohio, Jeromesville, Ashland County
    Jinma 284
    Default Re: Jinma 284 PTO HP for a finish mower
    The 6' brushhog FINISH mower is about as big as you would want to pull behind the 28hp jinma. I have a 5' finish and 5' brush hog that both work well behind my 284. I HAD a 6' "Brush-hog" rotary that was a bit too much on my hilly ground. I usually only cut everything 3 or 4 times a year so heavy higher grass on the rotary was too much on the 284. I think the 6' FINISH mower would be fine under normal mowing flat ground but on high grass or hilly ground maybe pushing it.
    Mark
    I may remember why I went to the other end of the shop, I'm just afraid once I get there I'll forget how to get back!
  3. #3
    Join Date
    Nov 2008
    Posts
    802
    US Virgin Islands
    Jinma JM304
    That's a good price for the Carini, but it is way too much mower for you tractor. Your 6' is pushing the limit and that 8' Carini needs a 45 hp tractor.
  4. #4
    Elite Member
    Join Date
    Feb 2007
    Posts
    2,845
    Earth
    A yellow one
    I'm going to sic the grammar police on your.
  5. #5
    Join Date
    Nov 2008
    Posts
    802
    US Virgin Islands
    Jinma JM304
    Busted! The keyboard ate it, I swear!
  6. #6
    Member
    Join Date
    Apr 2011
    Posts
    25
    McRae Ga
    I thought it might be a little to big. I ordered the parts to fix my Bush Hog today. I just use it to cut my yard which never gets very high and it is all flat. The tractor has never had a problem with the mower dragging it down.
    The only problem I have had is some overheating by the gauge on the dash. It seems the battery blocks over half the radiator. I replaced the fan belt today and added a set of gauges ( temp and oil pressure ) that way I will know for sure what the temp is running at. I have plans to relocate the battery but haven't had a chance yet. I am thinking of welding a bracket to the loader mount and setting it next to the motor in front of the brake pedal.
  7. #7
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Default
    Yea, 72" Caroni is what I have for my 284 & its perfect. I think any more is too much.
    Chris
  8. #8
    Advertiser
    Join Date
    Mar 2004
    Posts
    1,459
    Texas
    I have the lower battery box if you decide you want a bolt on box, you can always make your own also.The OEM bolts on where the front weights are if you do not have a loader, it drops the battery down below the radiator
    Tommy
    Affordable Tractor Sales
    "Your Jinma Parts Superstore"
    Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
    Attached Thumbnails Attached Thumbnails Jinma  284 PTO HP for a finish mower-4e34372956242dsc00268-jpg
  9. #9
    Member
    Join Date
    Apr 2011
    Posts
    25
    McRae Ga
    Will the new battery box work with the loader? If so how much.
  10. #10
    Advertiser
    Join Date
    Mar 2004
    Posts
    1,459
    Texas
    If you will send me pics of your I will confirm it for you, there is a bracket on there now that you remove, bolt this one in place of it.The only thing extra you have to do is make 2- lower hood mounting brackets that can come off this new bracket.
    The drop down battery box was made for the flip up hood yours is the clamshell right ? only the top opens right ?
    Tommy
Similar Threads
  1. Jinma 284 PTO issues
    By dunerdr in forum Chinese Tractors
    Last Post: 10-25-2011, 07:47 PM
  2. Jinma 284 PTO Clutch Adjustment
    By 3RRL in forum Chinese Tractors
    Last Post: 06-20-2009, 11:20 AM
  3. Mowing jinma finish mower question.
    By TSMART in forum Chinese Tractors
    Last Post: 09-29-2008, 08:31 PM
  4. Mowing Parts for Jinma Finish mower
    By rkevis in forum Chinese Tractors
    Last Post: 02-20-2007, 11:18 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
