DoctorZoidberg
Member
- Joined
- Apr 21, 2013
- Messages
- 37
- Location
- Pittsfield, MA
- Tractor
- 2021 Branson 3515ch (hydrostatic cab)
Hello,
I recently purchased an Iron Horse tractor (Jinma 284) that came with a JW-03 backhoe attached. I have a manual for the tractor itself but I am unable to locate a manual for the backhoe. I am looking to get some 3-point hitch implements for the tractor but I am unsure of how to remove the backhoe from the tractor in order to hook up the implements to the 3-point hitch. From what I can tell the backhoe has its own auxiliary hydraulic pump that is attached to the tractor directly above the PTO with 4 bolts (see attached picture). My question is, in order to remove the backhoe I assume I need to unbolt the entire pump and not just disconnect the hoses, is this correct? If so, is there some sort of cover that goes over where the pump is currently attached? I bought the tractor used and it did not come with any sort of cover for that.
Also, from what I can tell this is a "sub-frame" mounted backhoe and not a 3-point hitch mount backhoe and I just want to verify that is indeed correct? Once the backhoe is removed, is there still a standard 3-point hitch still attached to the tractor or was that removed in order to install the backhoe in the tractor? I see things on the tractor that look very similar to the 3-point hitches I have used in the past on other tractors but it does look different enough to what I am used to to make me question it! Which parts would I disconnect and leave with the backhoe and which stay on the tractor?
Sorry the pictures don't show all of the hook ups, I can take better ones tomorrow when it is light out again. I have highlighted where I think I need to disconnect the backhoe, any tips or advice would be greatly appreciated. (I have also included the original photos so you can see a bit better.)
Thank you!
Thank you!
