Page 8 of 8 FirstFirst ... 5678
Results 71 to 72 of 72
  1. #71
    Join Date
    Nov 2011
    Posts
    88
    Amboy WA
    Rhino 324
    Default Re: did I break anything?
    I have the preheater or I guess better described as a flame system in the intake. There is no option for glowplugs.
    There is no port to add to at the fuel filter, like st455dan's is set up. Mine is that way from the factory, and matches the books. I like the idea of the little jar to make it work easily, but there is not a lot of room above the heater and under the hood. I was hoping that someone had an idea for where I could get one.
  2. #72
    Veteran Member Bob Rooks's Avatar
    Join Date
    Feb 2007
    Posts
    2,234
    Bothell & Silverdale, WA
    Yuchai Bulldozer
    Quote Originally Posted by whynot162 View Post
    Ok, here is the fitting I made. Easy to do. Just drill and tap for 1/8" NPT and install a small needle valve and tube to your reservoir. You will also have to install a return line to the tank from your new reservoir- ok to go via the injector leak-off lines.
    -imga0890-jpg -imga0891-jpg
    Yuchai YCT dozer, Mustang 2040 skid steer, Mitsubishi MS035 Mini-Ex, Trimble equipped 7' Dual Dozer, and a LiTW BH7600 back hoe for sale.
Similar Threads
  1. Break in oil
    By BOC in forum John Deere Owning/Operating
    Last Post: 06-02-2012, 10:00 PM
  2. What did I break & how do I fix it?
    By Jmidjr in forum Kubota Owning/Operating
    Last Post: 08-08-2011, 08:08 PM
  3. Break In
    By SABULA FARMER in forum Bobcat Tractors
    Last Post: 08-04-2010, 08:44 PM
  4. Has anyone ever had this break?
    By KenGod in forum Kioti Owning/Operating
    Last Post: 08-27-2009, 08:01 PM
  5. What did I break?
    By slim in forum Parts/Repairs
    Last Post: 06-14-2007, 01:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2014 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
