Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
  1. #21
    New Member
    Join Date
    May 2018
    Posts
    1
    Foton FT404
    Default Re: Foton FT404 electric fuses problems
    Didn't find a thread more appropriate, so I'll just write my experience here. I swapped the original Foton 404 alternator for a bosch internal regulated one (B+/D+ wires only). Seems to be working well. I spliced into the switch ON positive to feed an "idiot light" and wired the other wire of the light to D+ post on alternator. B+ is the same as before for the original alternator.
    I added a cheap chinese volt meter to check the voltage from cabin, it fit right in to the dash in an empty button rectangle. regulates to ~14.2v without any load, drops to ~13.8v with high beams on.
    Foton FT404 electric fuses problems-img_7563-jpg
  2. #22
    New Member
    Join Date
    Jul 2017
    Posts
    4
    North Collins NY
    Foton FT404
    Quote Originally Posted by jkfoton View Post
    Thanks for the info, what model Bosch did you use?
    Did the original brackets work? I had to make custom brackets. I'll look up the Bosch alternator , and it's connections
Similar Threads
  1. Oil & Fuel foton 404 tractor fuel problems
    By johnpa in forum Chinese Tractors
    Last Post: 04-12-2015, 01:42 PM
  2. Foton 504/404 info, or experiances with foton.
    By tangstang79 in forum Chinese Tractors
    Last Post: 01-23-2014, 08:21 AM
  3. 2006 foton 404 3pt. problems
    By lej in forum Parts/Repairs
    Last Post: 11-20-2013, 06:54 PM
  4. FT404 hydraulic flow GPM and backhoe question
    By Wa11banger in forum Chinese Tractors
    Last Post: 11-01-2013, 10:25 PM
  5. Snow Differential lock broken on Foton FT404-2009
    By traktorz in forum Chinese Tractors
    Last Post: 10-23-2012, 08:09 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
