DoctorZoidberg
Member
- Joined
- Apr 21, 2013
- Messages
- 37
- Location
- Pittsfield, MA
- Tractor
- 2021 Branson 3515ch (hydrostatic cab)
Hello again!
I have been trying to get some of the electrical things working again on my tractor and step #1 for me was to check all the fuses. Well, they all look good but when I started looking into the fuse box layout it appears the guy before me may have screwed up some of the fuses. Does anyone happen to know exactly what the layout is supposed to be? According to the only pictures I can find online it looks like not only am I missing fuses but also may have some in the wrong place!
The tractor has been starting fine (until yesterday at least), electrical panel seems to work OK and the headlights even come on. Electrically the only things that didn't seem to be working are the rear work light and the flashers.
I went to start the tractor yesterday, turned the key and the panel turned on fine. I turn the key to the start position and absolutely nothing happens, starter doesn't even tick. I would like to get my fuse box straightened out before digging in much further, including replacing ALL the fuses to be sure they are all good. After the fuses are good I plan on trying to use the screwdriver trick to try to start the tractor to see if I can narrow down where to continue looking.
Here is a picture of what my panel looks like currently, which is exactly as it was when I got it (used).
Thanks in advance!
Thanks in advance!
