bjr
My Power steering reservoir keep losing oil and the engine oil sump is rising, with no external steering oil leaks, I'm guessing the PS pump is leaking into the crankcase. Sooo, is there a replacement shaft seal doable or will I have to replace whole pump? I'm concerned that a bushing or shaft bearing went away causing seal to rupture. I'm done hayin' for the season so now I'll be able to tear it apart and wait for parts shipments. Any input is appreciated thanks. bjr
