Page 5 of 5 FirstFirst ... 2345
Results 41 to 49 of 49
  1. #41
    Gold Member Smalljobs's Avatar
    Join Date
    Mar 2009
    Posts
    327
    Massachusetts
    Jinma 284
    Default Re: Convert Chinese Backhoe to Prince BH Control Valve Assembly?
    Update:
    I turned the entire valve around and ran into some problems. After I welded the new mounting plate, I could not fit the valve back inside...finally it fit. Now I have about two hours of seat time on it. It's both FAST and PRECISE...Amazing. I'm having a problem with the boom dropping too fast. I think the OEM application for this valve was for a smaller BH despite the fact I've rearranged the orifices in the valve stack. In fact , I'm now thinking about inserting an adjustable restrictor valve in the boom dump cylinder discharge. I need more seat time. The new valve makes it faster and more precise so my plan it get some hours on it first. A new suprise was the boom "float" I'm learning about.
    A big PLUS is the swing: The Chinese valve forced me to bump the stick and hope for the best. Now I can nudge the swing precisely a 1/2" or so with no trouble. The control of this DINOIL valve is great!
    Steve Anderson
    Jinma 284LE w/Creeper/Koyker 160 Loader/Markham Toothbar, Frame mounted HWO4X backhoe, 64" John Deere 3 PH Snow blower,3 PH splitter, Bro-Tek thumb, Jinma 8" chipper, Loader mounted Meyer plow
  2. #42
    New Member
    Join Date
    Jun 2012
    Posts
    10
    cantonment fl
    Kubota L3300 DT GST
    hi Steve my name is William Donahoo I live in Cantonment Florida and i'm interested in your Jinma backhoe control spool valve assembly and hoses I have a FarmPro BKHOE 30 attachment I think it is the same as the Jinma.
    My spool valve assembly is a series of 8 blocks bolted together by 4 - 12mm bolts about 12" long my email is donahooz@aol.com cell# is 850-968-0178 call text or email me and I can send you pics .
  3. #43
    Join Date
    Mar 2009
    Posts
    327
    Massachusetts
    Jinma 284
    Youve got mail
    Steve Anderson
  4. #44
    New Member
    Join Date
    Jun 2012
    Posts
    10
    cantonment fl
    Kubota L3300 DT GST
    hi steve when you installed the new valve how did you go from metric fittings on the cylinders to the JIC or NPT fittings on the prince spool valve? I've seen adapters but there $34 a piece times 14
  5. #45
    Join Date
    Mar 2009
    Posts
    327
    Massachusetts
    Jinma 284
    I used screw-on adaptors from Ranch Hand on all but one cylinder. For that one cylinder I'd already changed over the hose by welding on a male JIC as per image below. This was done by removing the China ORFS female end from the Chinese hose and welding it to a male JIC. From there I made up my own hose using common "reusable hose ends".
    Convert Chinese Backhoe to Prince BH Control Valve Assembly?-hose-conversion-jpg
    Steve Anderson
  6. #46
    New Member
    Join Date
    Jun 2012
    Posts
    10
    cantonment fl
    Kubota L3300 DT GST
    thanks Steve give me a call or text when you get ready to sell thanks Will
  7. #47
    Join Date
    Mar 2009
    Posts
    327
    Massachusetts
    Jinma 284
    Springtime is coming and I'm happy with the new backhoe valve with enough hours before winter. Soon I will make one posting with photos to sell off all the remaining HW04 parts as noted below. I want to sell all the OEM hoses and spares in one lot. The BH control valve together with numerous spare joystick linkage parts will also go as one lot. I prefer local pickup in central Massachusetts as this stuff is oily and not easy to pack. Will post on Craigslist as well.
    The HW04 BH valve worked perfectly with no issues, leaks, etc.
    Contact me privately to anderson@gdsconsulting.com
    Steve Anderson
  8. #48
    Super Member dfkrug's Avatar
    Join Date
    Feb 2004
    Posts
    5,740
    NorCal
    05 Kioti CK30HST w/ Prairie Dog backhoe
    Interesting valve substitution, SMALLJOBS. I am glad the Dinoil valve is working well.
    It looks like the new valve does not include any work-port relief valves. Is that also true
    of the Chinese valves?
    Interesting that you go to China a visit the factories before a purchase. I would assume
    those are very large purchases for your company?
    I am using Alibaba for the first time, to import a small Chinese excavator. I really should
    have visited the factory first, as you did, but I can't really justify the cost. I AM getting a
    spare valve stack for my new mini-X, as I don't hear much good about Chinese hydraulics.
    I hope it has work-port RVs, but I am not expecting that.
  9. #49
    Join Date
    Mar 2009
    Posts
    327
    Massachusetts
    Jinma 284
    Quote Originally Posted by dfkrug View Post
    Are you already committed to Alibaba? If not, contact me privately.
    Steve Anderson
Similar Threads
  1. Help to hook up Prince flow control valve
    By memphismark in forum Hydraulics
    Last Post: 07-05-2014, 01:23 AM
  2. Backhoe Control Valve Assembly leak on backhoe
    By JoelD in forum Kioti Owning/Operating
    Last Post: 04-21-2014, 07:23 PM
  3. Help with float on a prince control valve
    By kevinwak in forum Hydraulics
    Last Post: 01-06-2012, 09:11 AM
  4. Replies: 2
    Last Post: 11-23-2011, 11:45 AM
  5. Prince SV Sectional Control Valve Question
    By Cocre in forum Hydraulics
    Last Post: 09-14-2009, 04:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
