Burke4721
I am going to replace the valve block on my Backhoe. The valves always leaked (when I used it) I set the hoe aside for a while as I had no need for it. Now I do. The Valve assemble is junk due to my neglect. Rusted tight.
I bought a Chief Series 22 from Bailey International LLC, 6 spool valve, 10 GPM, max pressure 3600. I am not good at reading Chinese but I believe the PTO pump puts out 10 GPM the valve has SAE 10 in/out ports and SAE 8 working ports. Does anyone have experience with this valve? It was $300 cheaper than the prince.
I figure while I am at it I might as well replace the hoses too (bit dry rotted) to get the JIC fittings as I've seen discussed on the forum. I'm going to take them off and take the whole mess to a local hose place to make the hoses. Any info I should be giving the hydraulic shop guys.
Any pointers from the pros here on TBN?
Thanks Ed.
Thanks Ed.
