Results 1 to 1 of 1
  1. #1
    Join Date
    Mar 2015
    Posts
    85
    knoxville,tn
    180 Dragon
    Default SatohS550G... rebuilding the carb
    SatohS550G... rebuilding the carb-satoh-004-jpgits next to impossible to find a Carb kit for a ISO carb on a Satoh S550G BUT
    a carb kit for a S650G can be modified to fit ... carb kit # S.70586 replaces G064 3233 990
    The plunger arm shaft hole needs to be drilled out a little larger. drill it out ONLY after installing on the carb.. see pic
    the next thing is you have to use the old needle spring. the needle spring that comes in the kit is too short.
    other than that you are good to go.. the important gaskets in the kit that you need match up
Similar Threads
  1. Replies: 4
    Last Post: 02-14-2013, 08:45 AM
  2. Rebuilding OR Clutches
    By tderrick in forum General Vintage Tractors
    Last Post: 09-26-2009, 07:56 PM
  3. Rebuilding a sprayer...
    By pashworth in forum Build-It Yourself
    Last Post: 03-18-2009, 02:16 AM
  4. Rebuilding my shack
    By tallyho8 in forum Projects
    Last Post: 08-06-2007, 07:05 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
