Results 1 to 6 of 6
  1. #1
    Join Date
    Jan 2012
    Posts
    98
    Bloomingdale, NJ
    2005 John Deere 990
    Default 2001 Jinma ty 395i tractor
    I found this 2001 Jinma 395i TLB tractor on CL for 14k OBO. the ad says that "It has a brand new whole complete 35hp.diesel motor alt., injector pump ,starter ,&more" You can see it here https://newjersey.craigslist.org/grd/5404939688.html. I have a friend who is possibly interested in it. I don't know anything about Jinma tractors apart from the fact that they are Chinese. I don't know how easy it is to get parts for them or how reliable they are or anything like that. In addition I question why this one needed a new complete engine since the add says that it has 83 hours on it. Of course maybe the 83 hours is on the new engine.
    Thanks for the input.
    Rob
  2. #2
    Join Date
    Dec 2006
    Posts
    1,495
    Coastal Rhode Island
    Jinma 354, purchased 2007
    Default Re: 2001 Jinma ty 395i tractor
    The tractor is a Jinma 354.
    82 hours is about what you'd get if you ran it without changing the transport fluids from the factory until the engine stopped. If that's the case then the transmission and differentials may have issues.
    You can get a brand new 35HP from Northern Tool for $15,999 with free delivery (NorTrac 35XT 35 HP 4WD Tractor with Front End Loader With Ag. Tires | 35 HP Tractors| Northern Tool + Equipment)
    That's with the Koyker loader, which is worth about $3500 by itself. That's basically the same tractor, although I think Northern has switched to a different Chinese manufacturer than Jinma. But it's also 15 years newer.
    The LW7 backhoe on that tractor is not well-regarded. The tires are turf tires, which is an upgrade. Since it's four-wheel-drive you have to make sure that the front/rear size ratio was maintained when the tires were switched out, otherwise there's going to be problems. (I don't know how to tell, though).
    That's a lot of money for a 15-year-old tractor.
  3. #3
    Join Date
    May 2005
    Posts
    1,119
    Eastern WA
    Jinma JM354
    I have to agree 14 grand for that tractor is wayyy to much. I own a 01 354 without a FEL and it's good machine but probably only worth 3-4 thousand at most. Do some more searching bjr
    QUOTE=quicksandfarmer;4346321]The tractor is a Jinma 354.
    That's a lot of money for a 15-year-old tractor.[/QUOTE]
  4. #4
    Elite Member
    Join Date
    Feb 2007
    Posts
    2,845
    Earth
    A yellow one
    Do not walk away from that tractor, RUN!
  5. #5
    Gold Member
    Join Date
    Jul 2006
    Posts
    291
    Pittsburgh, Pa
    Ford 1900 - Steiner 420 - Black Craftsman Pro 24hp - Simplicity ZT-2500
    That's nuts. $1400 yes, 14g's is crazy!
    Steve
  6. #6
    Platinum Member Kubota 2350's Avatar
    Join Date
    Aug 2009
    Posts
    634
    Michigan, In The Thumb
    2016 JD 3046R Cab ...................... Mower: 2016 Scag Tiger Cat II ZTM
    Quote Originally Posted by Bob Rooks View Post
    I second that, I just sold a 2002 JD 4310 with a 430 loader and a back blade for that.
    John
    2016 JD 3046R Cab, FEL, Forks, Box Blade, Power Angle Rear Blade, Rear Tiller, and a 6' Brush Hog
    2016 Scag Tiger Cat II Zero Turn Mower
    Gone to new homes
    Kubota BX 2350
    John Deere 4310
Similar Threads
  1. 2001 TN75 NEW HOLLAND TRACTOR
    By rjmanes in forum Parts/Repairs
    Last Post: 03-28-2014, 02:38 PM
  2. 2001 jinma 220 radiator issue
    By Tintman in forum Chinese Tractors
    Last Post: 01-27-2014, 09:01 PM
  3. Used Kubota 2001 L4300F-R tractor
    By Silvathins in forum Kubota Buying/Pricing
    Last Post: 07-27-2004, 09:12 PM
  4. 2001 Jinma 354 Rear Hyd. Vent Leak
    By smittysdi in forum Parts/Repairs
    Last Post: 04-04-2004, 02:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
