Page 13 of 13 FirstFirst ... 310111213
Results 121 to 124 of 124
  1. #121
    Join Date
    Dec 2006
    Posts
    1,438
    Coastal Rhode Island
    Jinma 354, purchased 2007
    Default Re: Advice on potential purchase (Nortrack 3500B)
    I think Bob's onto something. Whether you keep it or sell it, its value is at its lowest as-is/where-is. It's worth more in a garage than it is in the field, and it's worth more fixed than it is broken. Do you think a roll-back will be able to move it with one track frozen? If so I think that's money well spent. Even if you end up just selling it as-is you've removed the uncertainty of how to move it. A few years ago I hired a roll-back to move a minivan and my recollection is it was reasonable, maybe $85.
  2. #122
    Join Date
    Feb 2016
    Posts
    129
    Edgewood, WA
    John Deere 1020
    Bob,
    Yuchai Dozer Brake Adjustment – CTOA
    Looking at this thread from CTOA, it seems this is as far as I have to go to fix my dozer. When you state the bull gear shaft is broken, that is the part shown in post #36155 correct?
    Which is the same part from the cirgle g link below. right?
    252L.39.53B ( Semi axle gear ) | Jinma Tractor Parts, Farm Pro Tractor Parts | Circle G Tractor Parts
  3. #123
    Elite Member
    Join Date
    Feb 2007
    Posts
    2,843
    Earth
    A yellow one
    Quote Originally Posted by PNW1020D View Post
    Bob,
    Yuchai Dozer Brake Adjustment CTOA
    Looking at this thread from CTOA, it seems this is as far as I have to go to fix my dozer. Yes, if that's the issue. When you state the bull gear shaft is broken, that is the part shown in post #36155 correct?
    Yes.
    No.
    That is the pinion shaft and gear (semi axle gear #6). It drives the bull gear.,
    If you have the identical situation as the CTOA thread - broken bull gear/sprocket shaft (drive shaft #19), then this is the main part that you need, plus any gaskets and seals:
    Z�5.39.537 ( Drive shaft ) | Jinma Tractor Parts, Farm Pro Tractor Parts | Circle G Tractor Parts.
    Advice on potential purchase (Nortrack 3500B)-final-drive-jpg
  4. #124
    Elite Member
    Join Date
    Feb 2007
    Posts
    2,843
    Earth
    A yellow one
    If that is the case, I would also consider replacing the bearings too, as they have been run in oil with metal shavings.
Similar Threads
  1. MF 1754 Potential Purchase
    By onionfmr in forum Massey Ferguson Owning/Operating
    Last Post: 11-30-2015, 08:56 PM
  2. Buying Advice Please advise on a potential purchase ...........
    By B52 in forum Kioti Buying/Pricing
    Last Post: 10-20-2015, 11:56 AM
  3. Potential purchase, 2011 BX25, looking for honest feedback
    By Jonohio in forum Buying/Pricing/Comparisons
    Last Post: 09-11-2015, 09:26 PM
  4. DK55 problems - potential purchase
    By TennFire in forum Kioti Owning/Operating
    Last Post: 09-17-2010, 11:04 AM
  5. Buying Advice Advice Needed on Potential L4400DT Purchase
    By kponds in forum Kubota Buying/Pricing
    Last Post: 02-18-2006, 04:07 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
