I dont wanna pull it because I am scared hahaha.
Mine def go through the floor boards. So i will also check to see if the "bar" that both the pedals attach to is properly lubed ect. As you have stated this gets all gunked up and starts to stick.
It must be an adjustment issue. I sprayed all adjustment nuts and rods down last night with PB blaster so I will hopefully get home tonight and start to tinker.
Any other info. advice. I hope the right track is actually getting power? Some state the dozer will drive in a straight line even with only one track operating and will display symptoms mine is when a final drive is broken?
