Oil & Fuel Kama 554 burns my eyes at idle.
   / Kama 554 burns my eyes at idle. #1
schmalts
Wisconsin
Kama 554
This tractor has always stunk and lite smoked unless it's warm out or the tractor is full operating temperature. I know these older models ran dirty but good grief. Is there a way to clean it up at idle? Pump adjustment?
   / Kama 554 burns my eyes at idle. #2
   / Kama 554 burns my eyes at idle. #3
You will also see improved efficiency by installing a 180° - 190° thermostat and a coolant recovery system.
   / Kama 554 burns my eyes at idle. #4
You might check the pump timing, and the pressure at the injector.
   / Kama 554 burns my eyes at idle. #5
He can pop test the injectors and check their spray pattern, but how would he check the pop pressure given that he probably can't afford a diesel test bench?
   / Kama 554 burns my eyes at idle. #6
Thread Bump...
Bob have you seen the Pop pressure checkers on E bay. like this?
Diesel Injector Nozzle Pop Pressure Tester Dual Read Bar/PSI Gauge S6H W/Filter | eBay
Looks like the pop pressure could be checked and even dialed in on injectors where the spring preload can be adjusted. (I would think).
I saw some with gauges that only go to 6000psi to.
Looked like a way to check just how close each injector is to each other and maybe even if an injector is a dribbler,
Or where 1 bad injector has been replaced as a way to insure the replacement is at least (in the ball park) to the remaining originals.
I haven"t seen a post where anyone has tried one of these little checkers but they do look interesting.
   / Kama 554 burns my eyes at idle. #7
   / Kama 554 burns my eyes at idle. #8
I just got a reply from them, and as I expected it's made in China. That's not necessarily a bad thing, but I don't think replacement parts are available.
