Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    New Member
    Join Date
    Nov 2016
    Posts
    9
    Walnut Grove, AZ
    Dong Feng Taskmaster 425
    Default Dong Feng parts
    All the posts I can find on Dong Feng parts are at least 10 years old. Specifically, I'm looking for the left steering arm for a 2005 Dong Feng 254 tractor. AliExpress has it listed, but my order was cancelled because the seller never shipped it. The part number is 254 31 201 Arm, with the related 304 31 202-1 bushing.
    My steering arm is broken, and I had it welded. It lasted 11 hours.
    Has anyone dealt with this in the last few years? I've contacted every Chinese parts shop I can find, and no one has been able to find it.
    Thanks in advance.
  2. #2
    Gold Member TTTTTT's Avatar
    Join Date
    Mar 2008
    Posts
    265
    Bowmanville, Ontario
    Dong Feng 354 (Oct 2008)
    Default Re: Dong Feng parts
    Hi I have 2007 DF354. Not sure where you are? I'm in Canada, I get my parts from Ray Hillman, in Devonn Alberta. " Hillman implement s. He sells DF parts. Google him, you'll find him. In the states, there's Artrac I think, Chip I think is his name.
    DF-354 (Oct.2008), Town Sunny 404 Loader,
    Town Sunny 3pt BH -6',
    3pt Log Splitter - 26",
    3pt 12" PHD
    8' Snow Plow Blade adapted to FEL,
    3 pt 7' Rear Blade,
    FEL / 3pt Forks,
    Hydraulic Toplink.
    3pt Hydraulic Crane
  3. #3
    New Member
    Join Date
    Nov 2016
    Posts
    9
    Walnut Grove, AZ
    Thanks. I have found both on the 'net and will contact them today.
    john
  4. #4
    New Member
    Join Date
    Nov 2016
    Posts
    9
    Walnut Grove, AZ
    Neither of those contacts is able to get this part. Guess I'll get it welded again. I will probably sell this machine and get something easier to maintain.
  5. #5
    New Member
    Join Date
    Mar 2015
    Posts
    20
    Draper, VA
    Dragon 274
    304.31A.215 Steering arm 304.31.202-1 Bush, DONGFENG Tractor Parts, 304
    34.31A.215 Steering arm + 34.31.22 1 Bush, DONGFENG Tractor Parts, 34 & 354-in Tool Parts from Home Improvement on Aliexpress.com | Alibaba Group
    (from AliExpress Android)
    Is this it?
  6. #6
    New Member
    Join Date
    Nov 2016
    Posts
    9
    Walnut Grove, AZ
    Quote Originally Posted by td1howard View Post
    3�4.31A.215 Steering arm + 3�4.31.2�2 1 Bush, DONGFENG Tractor Parts, 3�4 & 354-in Tool Parts from Home Improvement on Aliexpress.com | Alibaba Group
    Is this it?
    This is similar, but not the right one. I'm posting a pic of my part.
    AliExpress shows 26 in stock, but the order was cancelled because the seller never shipped it. My questions about this to AliExpress have gone unanswered. Ray Hillman in Alberta told me those parts are discontinued due to high failure rates. I'd be happy to find a used part or a tractor being parted out just to get it running again.
    Dong Feng parts-17020914-jpg
  7. #7
    New Member
    Join Date
    Mar 2015
    Posts
    20
    Draper, VA
    Dragon 274
    Quote Originally Posted by John Dennison View Post
    304.31.215-4 Right linking arm 304.31.202-1 Bush, DONGFENG/EAST WIND Tractor Parts, 20-30HP
    34.31.215 4 Right linking arm + 34.31.22 1 Bush, DONGFENG/EAST WIND Tractor Parts, 2 3HP-in Tool Parts from Home Improvement on Aliexpress.com | Alibaba Group
    This one looks closer. May be something they changed the design a little bit.
  8. #8
    New Member
    Join Date
    Nov 2016
    Posts
    9
    Walnut Grove, AZ
    3�4.31.215 4 Right linking arm + 3�4.31.2�2 1 Bush, DONGFENG/EAST WIND Tractor Parts, 2� 3�HP-in Tool Parts from Home Improvement on Aliexpress.com | Alibaba Group
    That's the right side. I need the left side. I might be able to weld the lug on to it. I will look at my right side arm and see if the hole pattern is the same.
  9. #9
    New Member
    Join Date
    Mar 2015
    Posts
    20
    Draper, VA
    Dragon 274
    If you have not contacted the store that has this one, that might be worth a shot as well.
  10. #10
    Join Date
    Oct 2010
    Posts
    731
    If you cleaned it up and used 309 or a 312 ss rod you'd have better luck with the welding...........M
Similar Threads
  1. Dong Feng Bulldog 245 Looking for parts source
    By benjschil66 in forum Chinese Tractors
    Last Post: 09-04-2014, 12:58 AM
  2. Comparison Dong Feng
    By Barry Hayes in forum Chinese Tractors
    Last Post: 04-28-2012, 03:05 PM
  3. Dong Feng Parts
    By chainsawmike in forum Chinese Tractors
    Last Post: 03-19-2009, 11:37 PM
  4. Dong Feng 254b Parts?
    By JackMentink in forum Chinese Tractors
    Last Post: 01-04-2007, 10:45 AM
  5. Dong Feng
    By zekeman in forum Chinese Tractors
    Last Post: 08-17-2004, 03:02 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
