Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Sep 2017
    Posts
    2
    VERO BEACH
    jinma newholland tn75
    Default jinma backhoe hydraulics
    Does someone know where to get cylinder parts for jinma backhoe? Cylinders will not hold pressure and are weak. Stabilizers will not stay up. Thanks
  2. #2
    Elite Member
    Join Date
    Feb 2007
    Posts
    2,843
    Earth
    A yellow one
    Default Re: jinma backhoe hydraulics
    Welcome to TBN.
    One of the places you can get replacement parts is Circle-G Tractor. What year/model is the backhoe, and did you buy it new?
    Do all of the cylinders seem "weak" or is it just the stabilizer cylinders?
  3. #3
    New Member
    Join Date
    Sep 2017
    Posts
    2
    VERO BEACH
    Quote Originally Posted by Bob Rooks View Post
    Welcome to TBN.
    Thanks for reply. Bought hoe back in 2004. Sat in storage since. Only ID I can find is Y 1 . Only large piston at top that curls the arm is weak, support cylinders bleed down and arms sink. Again Thank you
  4. #4
    Elite Member
    Join Date
    Feb 2007
    Posts
    2,843
    Earth
    A yellow one
    Quote Originally Posted by denzman View Post
    The problem I had with my LW-6 back hoe is that the cylinder cup seals disintegrated from using synthetic AW-32 hydraulic oil. Bad cup seals will cause your symptoms - pistons leaking by. You may also have some cup seal debris stuck in your relief valve. It should probably be checked and cleaned. You will have to order seal kits by cylinder size. Seals should also be available from your local hydraulic shop, who can also rebuild the cylinders.
Similar Threads
  1. Replacing Backhoe Valve Jinma Frame Mount Backhoe
    By Burke4721 in forum Chinese Tractors
    Last Post: 10-22-2017, 07:46 AM
  2. Backhoe Jinma HW04 Framemount Backhoe For Jinma 454 issues
    By KyleG in forum Chinese Tractors
    Last Post: 02-27-2009, 08:29 PM
  3. jinma hydraulics
    By dpmink in forum Chinese Tractors
    Last Post: 02-24-2006, 01:38 PM
  4. jinma 284 hydraulics
    By dpmink in forum Parts/Repairs
    Last Post: 01-31-2006, 09:53 PM
  5. Backhoe Backhoe Hydraulics Jinma 284
    By PeteW in forum Chinese Tractors
    Last Post: 11-13-2005, 02:20 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
