Results 1 to 2 of 2
  1. #1
    New Member
    Join Date
    Feb 2018
    Posts
    6
    Nr Bordeaux, France
    Siromer (Jinma) 204E
    Default Jinma 204E banjo bolt re-fitting.
    Hi all,
    I got some good help and advice with my previous post thank you,, I hope I can get some experienced advice on this issue.
    One of the rigid lines from the second pump to the base of the steering column for the power steering, had a leak from where the banjo fitting is brazed to the pipe. With a lot of dismantling I managed to remove the offending pipe and have had it re-brazed at the local agricultural garage here in France and it looks like a new pipe now.
    My questions are about refitting the banjo bolt.
    1. I have obtained new washers from the same place, that they say they use these on their repairs (see photo), but having searched various forums, there seems to be various types and I don't know if these are the best to use? They are metal with a rubber (or at least flexible) centre, slightly raised with respect to the metal part.
    2. Slipping them onto the banjo bolt, there is a little slack, is this to allow them to be 'crushed' when they are tightened?
    3. Can anyone tell me the approximate torque to tighten them to? - again the various forum answers I have researched are confusing and vary considerably
    Many thanks
    Jinma 204E banjo bolt re-fitting.-p4230776-jpg Jinma 204E banjo bolt re-fitting.-p4230777-jpg
    Experience is gained by doing it for the first time - Soaking up information like a sponge....
  2. #2
    Veteran Member DLTTrekkers's Avatar
    Join Date
    May 2014
    Posts
    1,012
    Paarl South Africa
    Default Re: Jinma 204E banjo bolt re-fitting.
    Quote Originally Posted by baj33790 View Post
    Hi all,
    Many thanks
    Dowty washers ....the best you can get .
Similar Threads
  1. need banjo bolt/bolt pipe union farmtrac545
    By 545 in forum Parts/Repairs
    Last Post: 06-25-2013, 12:49 AM
  2. Siroma 204E (Jinma?) hydraulics questions
    By dwk789 in forum Chinese Tractors
    Last Post: 06-17-2013, 08:07 AM
  3. Banjo fitting leaking in the case.
    By davygp38 in forum Hydraulics
    Last Post: 09-15-2010, 09:52 AM
  4. Oil & Fuel ym240 banjo, and banjo bolt
    By jbrd in forum Yanmar
    Last Post: 03-25-2010, 07:40 AM
  5. SAE-8 Banjo Fitting Autocad
    By tomrscott in forum Build-It Yourself
    Last Post: 03-29-2005, 04:22 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
