GuglioLS
- Joined
- Feb 13, 2005
- Messages
- 1,143
- Location
- Edgewood, NM USA
- Tractor
- Jinma 354, 1953 Ford NAA Golden Jubilee, Komatsu Bulldozer
I am waiting on my Jinma 354 LE.
In the mean time I have been gathering up parts for a Hydraulic top link
and a Hydraulic vertical Lift arm link.
I am all set for the top link.
My Questions are related only to specifics of the adjustable Vertical connecting link for the 3 point hitch for the purpose of acquiring / modifying the correct Hydraulic Cylinder for length, Clevis Pin Diameter, and Clevis width for a Jinma 354.
1.How long is the adjustable vertical link that connects to the top of the 3 pt Hydraulic lift arm down to the Horizontal arm when set at the mid point? (Pin to Pin center distance) left side / right side don’t matter.
2. What is the ~ Min / ~ Max adjustment length.
3. What is the Pin Diameter on top? (Inch or mm)
4. What is the Pin Diameter on the bottom? (Inch or mm)
5. How much space is in between where the pin goes on the top.
6. How much space is in between where the pin goes on the Bottom.
Any usefull information will be greatly appreciated
Thank you
Thank you
