pasturesnew
Member
- Joined
- May 29, 2005
- Messages
- 30
Hi Phil,
Sounds like we have the same type injector pump. In which case, there are two drain plugs on the bottom (you found them). There is also a small banjo overflow towards the front (radiator side) with a rubber cap. Remove the cap and add oil a little at a time through the mushroom filler until it begins to drip out of the overflow - for some reason, it can take ages before it stops dripping but am told that is not a problem.
hope this helps - have a good day
ACM
ACM
