lakespirit
Thanks. I put the clutch together tonite and am planning to put the tractor together after work and give it a try. Best I can tell, from the tip of the main release lfinger to the tip of the aux tip is about 5.5mm, which is where I set them. Gues you can't see if you have the 2.5mm from the tip of the main relese finger to the throwout bearing until it's back together...what a pain in the butt this is. what's the cost of the new assembly, and what's it come with? Is everything preset?
