zogman
- Joined
- Sep 2, 2005
- Messages
- 109
- Location
- Lexington, South Carolina
- Tractor
- Kama TS354C & Ferguson TO20
Special thanks to Chip from ARTRAC for all the info...
TIRE PRESSURE:
Front (With Front End Loader) – 35 psi
Rear (With Backhoe) – 20 psi
ENGINE FIRING ORDER
1 – 3 – 4 – 2
50 HOUR SERVICE
Adjust Valve Clearance
• Intake (Cold) .20 – .25 mm
• Exhaust (Cold) .25 – .30 mm
Re-Torque Head Bolts
• 150 – 170 NM (Be sure to loosen, lubricate and then re-tighten head bolts)
Replace Oil, Oil Filter & Fuel Filter
• Oil Filter – NAPA # 1516
• Fuel Filter – NAPA # 3195
Check Air Filter
• Air Filter – NAPA # 2276
See attached .JPG for engine layout
TIRE PRESSURE:
ENGINE FIRING ORDER
1 – 3 – 4 – 2
50 HOUR SERVICE
Check Air Filter
