Gerifalte
Oleozz said:Great pics and I really enjoyed looking at those mountains in the background.
Thanks Oleozz. Those are the foothills. A small "preview" of the much larger Rockies.
michaelTS354 said:Off the topic here, but I was looking at your front end loader. It doesnt look like an Accutech or Koyker. Is it a chinese or home built?
HEC said:you guys have it all I guess.
crazymike said:Glad you are enjoying your tractor and snow.
Just some advice, and I'm sure some people will differ, but I recomend backing any small tractor on to your trailer.
I recomend this for a few reasons.
1) Your chances of flipping the tractor over backwards while loading/unloading are greatly decreased.
2) you can get a much better idea of where you are on the ramp, trailer much easier.
3) your sun shade doesn't catch the wind while driving
Also, I reccomend always using 4wd when loading on a trailer. With a higher trailer you risk the chance of backwheels spinning and shooting you off the trailer. In 4wd you will find the tractor loads straight and easy.
Additionally, trailer accidents most frequently happen when loading/unloading so make sure there is someone else around.
Finally, always place a block of wood between the rear of your trailer and the ground. This stops the trailer from lifting the back of the truck up when you are driving on. Once this happens your parking break is no longer stopping the wheels and your truck may roll away.
Hope this helps next time you have to trailer![]()
SPIKER said:G:
I'm sure you over loaded that single axle trailer load/limit rating.! these things with FEL weigh in somewhere around 4500 lbs. + depending on which FEL ya have maybe a bit more. weight probably 60/40 FEL on front (front/rear), just a guess though I'm sure a dealer can confirm actual weight & distrbution better...
MARKm
